55
I am having trouble connecting my Bluetooth speakers with a fresh 15.10 install (EDIT: applies to 16.04 as well). The speakers are connected however they are not listed as an available audio device.
I tried to load the Bluetooth module using:
sudo pactl load-module module-bluetooth-discover
Failure: Module initialization failed
The same speakers have worked perfectly on 14.04. Any ideas how I could properly load the module so I can use my speakers?
Melebius
  • 11,750
Solved by using SimFox3 answer in this thread.
Bug and possible solution: actually I found a bug in that make the headset unusable, it seems that the pulse audio module: module-bluetooth-discover works only if started after the X11 session is up. So I have a workaround.
Edit the file:
/etc/pulse/default.pa
and comment out (with an # at the beginning of the line) the following line:
#load-module module-bluetooth-discover
now edit the file:
/usr/bin/start-pulseaudio-x11
and after the lines:
   if [ x”$SESSION_MANAGER” != x ] ; then
        /usr/bin/pactl load-module module-x11-xsmp “display=$DISPLAY session_manager=$SESSION_MANAGER” > /dev/null
    fi
add the following line:
    /usr/bin/pactl load-module module-bluetooth-discover
This way the Pulse audio’s Bluetooth modules will not be downloaded at boot time but after x11 is started.
17
The solution in 16.10 is:
$ sudo apt install bluetooth pulseaudio-module-bluetooth
This answer was originally posted as an edit to the question.
Melebius
  • 11,750
15
Sometimes, it works after reboot, and such error appears later. In this case you can try the following, which works for me:
pactl unload-module  module-bluetooth-discover
kynan
  • 2,235
jmary
  • 666
  • 15
