I'm facing intermittent bluetooth connection issues where I can connect a device on startup and after a while (30mins) the connection will be degraded (skipping/jittery). If I then disconnect the device and attempt to reconnect it from blueman-manager I get the following two cases:
- A successful connection, after which the device is not listed as an ouptut in
pavucontrol - Connection error:
Connection Failed: Resource temporarily unavailable
Solutions attempted
- Unpairing/repairing the device
- Resetting the pulseaudio config (https://askubuntu.com/a/875891/1569612)
- Restarting pavucontrol (
pulseaudio -k) or restarting bluetooth (systemctl restart bluetooth.service) - Attempting to reload pulseaudio-discovery module (https://askubuntu.com/a/1062044/1569612) Above yeilds the following error
taylorswift2018@box:~$ pactl load-module module-bluetooth-discover
Failure: Module initialization failed
- Load pulseaudio after x11 (https://askubuntu.com/a/689297/1569612)
The output of systemctl status bluetooth.service
taylorswift2018@box:~$ systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-02-10 10:31:33 NZDT; 1h 49min ago
Docs: man:bluetoothd(8)
Main PID: 821 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18965)
Memory: 1.9M
CGroup: /system.slice/bluetooth.service
└─821 /usr/lib/bluetooth/bluetoothd
Feb 10 10:31:33 box bluetoothd[821]: Starting SDP server
Feb 10 10:31:33 box bluetoothd[821]: Bluetooth management interface 1.20 initialized
Feb 10 10:31:34 box bluetoothd[821]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSink/sbc
Feb 10 10:31:34 box bluetoothd[821]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/sbc
Feb 10 10:31:49 box bluetoothd[821]: /org/bluez/hci0/dev_00_16_94_29_CD_9E/sep1/fd0: fd(46) ready
Feb 10 12:09:15 box bluetoothd[821]: Unable to get io data for Headset Voice gateway: getpeername: Transport endpoint is not connected (107)
Feb 10 12:10:35 box bluetoothd[821]: Disconnecting failed: already disconnected
Feb 10 12:10:37 box bluetoothd[821]: Unable to get Headset Voice gateway SDP record: Operation already in progress
Feb 10 12:10:37 box bluetoothd[821]: connect error: Operation already in progress (114)
Feb 10 12:10:39 box bluetoothd[821]: connect error: Operation already in progress (114)
journalctlis not showing any errors
Hardware
- CPU: Intel i7 11700
- Motherboard: Gigabyte B560M DS3H AC
taylorswift2018@box:~$ inxi -Fxxxz
System:
Kernel: 5.13.0-28-generic x86_64 bits: 64 compiler: N/A
Desktop: Gnome 3.36.9 wm: gnome-shell dm: GDM3 3.36.3
Distro: Ubuntu 20.04.3 LTS (Focal Fossa)
Machine:
Type: Desktop Mobo: Gigabyte model: B560M DS3H AC v: x.x serial: <filter>
UEFI: American Megatrends LLC. v: F6 date: 08/23/2021
CPU:
Topology: 8-Core model: 11th Gen Intel Core i7-11700 bits: 64 type: MT MCP
arch: N/A L2 cache: 16.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 79872
Speed: 800 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 813 6: 807 7: 1045 8: 825 9: 2193 10: 4613 11: 4651
12: 1586 13: 4693 14: 1214 15: 4499 16: 4541
Graphics:
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: ASRock driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67df
Display: x11 server: X.Org 1.20.13 driver: amdgpu compositor: gnome-shell
resolution: 2560x1440~60Hz
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.41.0
5.13.0-28-generic LLVM 12.0.0)
v: 4.6 Mesa 21.2.6 direct render: Yes
Audio:
Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:43c8
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: ASRock driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aaf0
Sound Server: ALSA v: k5.13.0-28-generic
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Gigabyte driver: r8169 v: kernel port: 4000 bus ID: 03:00.0
chip ID: 10ec:8168
IF: enp3s0 state: down mac: <filter>
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtl8821ce v: v5.5.2.1_35598.20191029 port: 3000
bus ID: 04:00.0 chip ID: 10ec:c821
IF: wlp4s0 state: up mac: <filter>
Drives:
Local Storage: total: 2.27 TiB used: 25.01 GiB (1.1%)
ID-1: /dev/sda vendor: Western Digital model: WD20EFRX-68EUZN0
size: 1.82 TiB speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 0A82 scheme: GPT
ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
speed: 6.0 Gb/s serial: <filter> rev: 4B6Q scheme: GPT
Partition:
ID-1: / size: 456.96 GiB used: 25.00 GiB (5.5%) fs: ext4 dev: /dev/sdb2
Sensors:
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 27 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1438
Info:
Processes: 372 Uptime: 1h 21m Memory: 15.50 GiB used: 2.05 GiB (13.2%)
Init: systemd v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Shell: bash
v: 5.0.17 running in: server inxi: 3.0.38
