I am running Ubuntu Oneiric 11.10.
My understanding is that Gnome Classic is with Compiz effects, and Gnome Classic (No Effects) has no Compiz.
However, when i run Gnome Classic, compiz does not seem to be running. If I open compiz-settings-manager, I have all my settings, but none of them are taking effect.
Is there something I need to be doing to enable Compiz in Gnome Classic?
As requested in the comments of the answers, here is the output of ~/.xsession-errors:
gnome-session[20450]: DEBUG(+): GsmDBusClient: obj_path=/org/gnome/SessionManager interface=org.gnome.SessionManager method=Is
Inhibited
Inhibited
Inhibited
gnome-session[20450]: DEBUG(+): Starting app: /org/gnome/SessionManager/App37
gnome-session[20450]: DEBUG(+): GsmAutostartApp: starting jockey-gtk.desktop: command=sh -c 'test -e /var/cache/jockey/check |
| exec jockey-gtk --check' startup-id=102cff201a509beb8813189506573089800000204500036
gnome-session[20450]: DEBUG(+): GsmAutostartApp: started pid:20888
gnome-session[20450]: DEBUG(+): Starting app: /org/gnome/SessionManager/App29
gnome-session[20450]: DEBUG(+): GsmAutostartApp: starting update-notifier.desktop: command=update-notifier startup-id=102cff20
1a509beb88131895065698387500000204500028
gnome-session[20450]: DEBUG(+): GsmAutostartApp: started pid:20889
gnome-session[20450]: DEBUG(+): GsmAutostartApp: (pid:20888) done (status:0)
Gtk-Message: Failed to load module "rgba"
gnome-session[20450]: DEBUG(+): GsmDBusClient: obj_path=/org/freedesktop/DBus interface=org.freedesktop.DBus method=NameOwnerC
hanged
hanged
hanged
hanged
hanged
hanged
`menu_proxy_module_load': update-notifier: undefined symbol: menu_proxy_module_load
(update-notifier:20889): Gtk-WARNING **: Failed to load type module: (null)
Questioner
  • 6,959
To solve this problem edit this file:
sudo nano /usr/share/gnome-session/sessions/gnome-classic.session
and replace this line:
RequiredProviders=windowmanager;notifications;
with this one:
Then just logout and log back in and it should work fine. This solved the problem in my case.
EDIT 1:
1) to access the gnome panel menu now you need to use "windows key + alt + right click" on panels instead of "alt + right click"
2) another issue might be "alt + tab" but you just need to reassign it in Applications -> System Tools -> System Settings -> Keyboard -> Shortcuts
EDIT 2:
3) after system updates related to GTK or gnome you might need to reinstall any "custom" drivers for your graphics card, for e.g. NVIDIA linux driver
Anonymous
  • 11,979
Gnome Classic should run compiz if you have acceleration enabled (you can try to run /usr/lib/gnome-session/gnome-session-check-accelerated; echo $? and it should return 0), if it returns something else, it's probably that you don't have harware acceleration and so fallback to GNOME classic (No effects).
If no, is running /usr/bin/gnome-wm --replace replace your current environment with compiz ?
Jorge Castro
  • 73,717
didrocks
  • 2,452
Just for completeness,
another solution that works for me is to add "/usr/bin/compiz --replace" to the GNOME startup applications via:
gnome-session-properties
I lost the Alt-RightClick functionality too (Windows+Alt-Rightclick is necessary) but Alt+Tab is still working.
kind regards
Jorge Castro
  • 73,717
spy
Compiz effects frequently fail to load at startup in Ubuntu 10.04. To enable Compiz, I have to logout then login again. This usually does the trick.
Max
