When I first installed Ubuntu 11.10 with Gnome-Classic, Compiz wouldn't run, and so I solved it by asking here on askubuntu.
However, after the most recent set of updates a couple days ago, Compiz no longer automatically starts when I boot up and log in.
If I simply reload the window manager, then Compiz starts.
How can I get Compiz to start automatically?
Update: output of ~/.xsession-errors:
(nautilus:2985): Gtk-CRITICAL **: gtk_container_foreach: assertion `GTK_IS_CONTA
INER (container)' failed
(nautilus:2985): Gtk-CRITICAL **: gtk_widget_get_parent: assertion `GTK_IS_WIDGE
T (widget)' failed
(nautilus:2985): Gtk-CRITICAL **: find_menu_position: assertion `GTK_IS_MENU_SHE
LL (menushell)' failed
(nautilus:2985): Gtk-CRITICAL **: gtk_menu_item_get_submenu: assertion `GTK_IS_M
ENU_ITEM (menu_item)' failed
T (widget)' failed
(nautilus:2985): Gtk-CRITICAL **: gtk_image_menu_item_set_always_show_image: ass
ertion `GTK_IS_IMAGE_MENU_ITEM (image_menu_item)' failed
** (gnome-panel:2970): WARNING **: Failed to get pixmap 31457708, 751, 0
** (gnome-panel:2970): WARNING **: Failed to get pixmap 31457708, 928, 0
T (widget)' failed
T (widget)' failed
** (gnome-panel:2970): WARNING **: Failed to get pixmap 31457956, 751, 0
** (gnome-panel:2970): WARNING **: Failed to get pixmap 31457956, 928, 0
** (gnome-panel:2970): WARNING **: Failed to get pixmap 31458022, 751, 0
** (gnome-panel:2970): WARNING **: Failed to get pixmap 31458022, 928, 0
T (widget)' failed
T (widget)' failed
T (widget)' failed
T (widget)' failed
** (process:3159): DEBUG: Telepathy Indicator started
** (gnome-screensaver:3160): WARNING **: screensaver already running in this ses
sion
Questioner
  • 6,959
I had this problem too. I had to redo the changes to /usr/share/gnome-session/sessions/gnome-classic.session again.
Anonymous
  • 11,979
