I'm (desperately) trying to install VLC on my 14.04.
apt-cache policy vlc
returns:
vlc:
  Installed: (none)
  Candidate: 2.1.6-0ubuntu14.04.1
  Version table:
     2.1.6-0ubuntu14.04.1 0
        500 http://mirror.switch.ch/ftp/mirror/ubuntu/ trusty-updates/universe amd64 Packages
        500 http://mirror.switch.ch/ftp/mirror/ubuntu/ trusty-security/universe amd64 Packages
     2.1.2-2build2 0
        500 http://mirror.switch.ch/ftp/mirror/ubuntu/ trusty/universe amd64 Packages
When I try to install, then I get the infamous vlc-nox issue:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 vlc : Depends: vlc-nox (= 2.1.6-0ubuntu14.04.1) but it is not going to be installed
       Recommends: vlc-plugin-notify (= 2.1.6-0ubuntu14.04.1) but it is not going to be installed
       Recommends: vlc-plugin-pulse (= 2.1.6-0ubuntu14.04.1) but it is not going to be installed
Attempt to install vlc-nox leads to request of installation of libfreerdp1, and then to this message:
sudo apt-get install libfreerdp1
Suggested packages:
  freerdp-x11
The following packages will be REMOVED
  libfreerdp-cache1.1 libfreerdp-client1.1 libfreerdp-codec1.1
  libfreerdp-common1.1.0 libfreerdp-core1.1 libfreerdp-crypto1.1
  libfreerdp-gdi1.1 libfreerdp-locale1.1 libfreerdp-plugins-standard
  libfreerdp-primitives1.1 libfreerdp-rail1.1 libfreerdp-utils1.1
  libwinpr-crt0.1 libwinpr-dsparse0.1 libwinpr-environment0.1 libwinpr-file0.1
  libwinpr-handle0.1 libwinpr-heap0.1 libwinpr-input0.1
  libwinpr-interlocked0.1 libwinpr-library0.1 libwinpr-path0.1
  libwinpr-pool0.1 libwinpr-registry0.1 libwinpr-rpc0.1 libwinpr-sspi0.1
  libwinpr-synch0.1 libwinpr-sysinfo0.1 libwinpr-thread0.1 libwinpr-utils0.1
  libxfreerdp-client1.1 remmina-plugin-rdp
The following NEW packages will be installed
  libfreerdp1
Now, I don't understand why vlc installation would lead to removing these packages? Is there any way around this issue?
Already went through (reasonable) solutions suggested here, here, here, here, here apart from adding repositories.
Output of apt-cache policy libfreerdp-cache1.1:
  Installed: 1.1.0~git20140921.1.440916e+dfsg1-2ubuntu1~trusty1
  Candidate: 1.1.0~git20140921.1.440916e+dfsg1-2ubuntu1~trusty1
  Version table:
 *** 1.1.0~git20140921.1.440916e+dfsg1-2ubuntu1~trusty1 0
        500 http://ppa.launchpad.net/remmina-ppa-team/remmina-master/ubuntu/ trusty/main amd64 Packages
        100 /var/lib/dpkg/status
Output of apt-cache policy remmina-plugin-rdp:
remmina-plugin-rdp:
  Installed: 1.1.1-ppa1+484+201508180831~ubuntu14.04.1
  Candidate: 1.1.1-ppa1+484+201508180831~ubuntu14.04.1
  Version table:
 *** 1.1.1-ppa1+484+201508180831~ubuntu14.04.1 0
     1.0.0-4ubuntu3 0
        500 http://mirror.switch.ch/ftp/mirror/ubuntu/ trusty/main amd64 Packages
The first part of your problem is that you have disabled unstable PPAs or repos. Please take a look at this post for additional information. This would be the first step in solving your issue.
After you cleared up that, please enter the following into a Terminal window.
 sudo apt-get remove --purge vlc-nox
 sudo apt-get autoclean
 sudo dpkg --configure -a
 sudo apt-get -f install
 sudo apt-get autoremove
 sudo apt-get update
 sudo apt-get dist-upgrade
 sudo apt-get install vlc
Another recommendation would be using the official VLC repo than the Ubuntu one. These are kept up to date and are a lot more efficient in my opinion. If you want to do that, please enter the following below:
 sudo add-apt-repository ppa:videolan/stable-daily
 sudo apt-get update && sudo apt-get upgrade
Nickolaus L.
  • 146
Pretty simple. you are using a ppa that has numerous freerdp packages but not libfreerdp1.
https://launchpad.net/~remmina-ppa-team/+archive/ubuntu/remmina-master
So when trying to install vlc it depends on libfreerdp1 which is available in the ubuntu repos. However libfreerdp1 from ubuntu conflicts with some of your installed freerdp packages, they have to be removed to install vlc & libfreerdp1.
To resolve or proceed, several choices,
  1. use ppa-purge on the ppa, then install vlc.
  2. install vlc, lose all those packages (seems useless then to have ppa so 1 is better
  3. contact the ppa maintainers & report the problem, maybe they will explain why no libfreerdp1 & provide a vlc build that uses new packages/soname.
  4. See if you can rebuild vlc so libfreerdp1 isn't needed, ck. what vivid does where libfreerdp1 is gone.
  5. Don't install vlc, leave things as is.
doug
  • 17,212
-2
I recommend using aptitude on the command line to resolve dependency issues and broken packages, then revisit the answer given by Nickolaus L.
