https://i.sstatic.net/lwBqg.jpg
This is the error I am getting while installing VLC media player on Ubuntu 14.04 LTS, kindly help me with it, because I want to run my videos and audios on Ubuntu as well
Try this:
sudo apt-get update
sudo apt-get dist-upgrade
then run:
sudo apt-get install vlc
you should get this output:
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  fonts-freefont-ttf libaacs0 libbasicusageenvironment0 libbluray1 libcddb2
  libcrystalhd3 libdvbpsi8 libebml4 libgnutls28 libgroupsock1 libhogweed2
  libiso9660-8 liblivemedia23 liblua5.2-0 libmatroska6 libpostproc52
  libproxy-tools libresid-builder0c2a libsdl-image1.2 libsdl1.2debian
  libsidplay2 libssh2-1 libtar0 libupnp6 libusageenvironment1 libva-x11-1
  libvcdinfo0 libvlc5 libvlccore7 libxcb-composite0 libxcb-randr0 vlc-data
  vlc-nox vlc-plugin-notify vlc-plugin-pulse
Suggested packages:
  libbluray-bdj firmware-crystalhd gnutls-bin videolan-doc
Recommended packages:
  libdvdcss2
The following NEW packages will be installed:
  libvcdinfo0 libvlc5 libvlccore7 libxcb-composite0 libxcb-randr0 vlc vlc-data
0 upgraded, 36 newly installed, 0 to remove and 5 not upgraded.
Need to get 14.9 MB of archives.
After this operation, 63.2 MB of additional disk space will be used.
Do you want to continue? [Y/n]
That should get VLC installed.
If you still get an error instead, then please post back the output.
Also post the contents of your /etc/apt/sources.list.
gedit /etc/apt/sources.list
Another alternative, is to show us the content in /var/lib/apt/lists/:
open a command prompt Ctrl+Alt+T
cd /var/lib/apt/lists/
ls
Is your 14.04 install a fresh install, or was in an upgrade from a previous version of Ubuntu?
muru
  • 207,228
AllGamer
  • 1,217
This worked for me assuming we are from Pakistan we might be facing the same problem
hit alt + f2 type additional drivers open the app, this will open the window software & updates go to the ubuntu software tab below change the "download from", I selected the main server. close it
hit ctrl+alt+t (open the terminal) type and enter:
download will begin if its done you can open it by typing:
vlc &
else run
sudo apt-get -f install
which I had to after that, run the
Now it installed for me again to open it you can enter
vlc &
or simply go search it in the home menu
user93692
  • 142
Removing the vlc* packages and then installing vlc again seem to have solved my problem.
sudo apt-get purge vlc*
(do note that the previous command will delete your configuration data for vlc)
If it doesn't, I have also removed the videolan ppa from /etc/apt/sources.list.d/.
sudo rm videolan-master-daily-trusty.list
