I have a problem while trying to install VLC Media Player.
I type sudo apt-get install vlc in the Terminal, and this is what I get:
[sudo] password for hagaymosko:
Reading package lists... Done
Building dependency tree
vlc : Depends: vlc-nox (= 2.1.4-0ubuntu14.04.1) but it is not going to be installed
Recommends: vlc-plugin-notify (= 2.1.4-0ubuntu14.04.1) but it is not going to be     installed
Recommends: vlc-plugin-pulse (= 2.1.4-0ubuntu14.04.1) but it is not going to be     installed
What does that mean, and how do I fix it?
A J
  • 11,557
Hagaymosko
  • 141
