I am trying to install VLC on 12.04, but I'm running into these errors:
Reading package lists... Done
Building dependency tree
vlc : Depends: vlc-nox (= 2.0.3-0ubuntu0.12.04.1) but it is not going to be installed
Depends: libsdl-image1.2 (>= 1.2.10) but it is not installable
Depends: libtar0 but it is not installable
Depends: libxcb-keysyms1 (>= 0.3.8) but it is not installable
Recommends: vlc-plugin-notify (= 2.0.3-0ubuntu0.12.04.1) but it is not going to be installed
Recommends: vlc-plugin-pulse (= 2.0.3-0ubuntu0.12.04.1) but it is not going to be installed
How do I fix these errors and install VLC?
