84
The answers to related questions forget to:
  • remove the MySQL databases
  • remove the mysql user
  • remove the logs in /var/log
How do I uninstall MySQL completely?
muru
  • 207,228
Olathe
  • 4,310
  • 19
  • 24
Building off of another answer, open a terminal (press Ctrl+Alt+T) and run the following:
sudo -i
service mysql stop
killall -KILL mysql mysqld_safe mysqld
apt-get --yes purge mysql-server mysql-client
apt-get --yes autoremove --purge
apt-get autoclean
deluser --remove-home mysql
delgroup mysql
rm -rf /etc/apparmor.d/abstractions/mysql /etc/apparmor.d/cache/usr.sbin.mysqld /etc/mysql /var/lib/mysql /var/log/mysql* /var/log/upstart/mysql.log* /var/run/mysqld
updatedb
exit
If you want to delete the log of what you did while using the mysql client:
rm ~/.mysql_history
If you want to delete the logs of what all users on the system did while using the mysql client (the other users might be unhappy with this):
awk -F : '{ print($6 "/.mysql_history"); }' /etc/passwd | xargs -r -d '\n' -- sudo rm -f --
or for all logs including those outside of existing user home directories:
sudo find / -name .mysql_history -delete
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Olathe
  • 4,310
  • 19
  • 24
37
I found some help, but it did not remove everything. I added an asterisk before and after mysql like this:
sudo apt-get remove --purge *mysql\*
sudo apt-get autoremove
sudo apt-get autoclean
Zanna
  • 72,312
Foxsolo
  • 387
I used a collab of 2 answers, first I ran this
  • sudo -i
  • service mysql stop
  • killall -KILL mysql mysqld_safe mysqld apt-get --yes purge mysql-server mysql-client
  • apt-get --yes autoremove --purge
  • apt-get autoclean
  • deluser --remove-home mysql
  • delgroup mysql
  • rm -rf /etc/apparmor.d/abstractions/mysql /etc/apparmor.d/cache/usr.sbin.mysqld /etc/mysql /var/lib/mysql /var/log/mysql* /var/log/upstart/mysql.log* /var/run/mysqld
  • updatedb
  • exit
Then checked, but still had an error, so as backup, I ran this within the terminal.
  • sudo apt-get remove --purge *mysql*
  • sudo apt-get autoremove
  • sudo apt-get autoclean
Worked perfectly.
Another way, that worked for me, was to use Synamptic Package Manager. On the left hand pane,where it says: All, Installed, etc. there is an entry for Not Installed (residual config.) (or similar wording). Under there I found options to clear all MySQL install files. This worked for MySQL 5.7.
Zanna
  • 72,312
