I am attempting to install LAMP server so I can work on PHP and MySQL databases locally on Ubuntu 16.04LTS.
I got through a lot of the installation and then decided I wanted to start again (see below as to why). How can I remove everything associated with LAMP server that I have just installed and start again?
I went through the following steps when installing:
sudo apt-get install tasksel
and then
sudo tasksel install lamp-server
Upon going though these steps it asked me for a mysql password, which I (probably shouldn't have) left blank.
I then installed phpmyadmin, again leaving the password blank for root.
After installation of phpmyadmin I then had to use
sudo gedit /etc/apache2/apache2.conf
And add this line:
Include /etc/phpmyadmin/apache.conf
Attempting to login to phpmyadmin threw up an error about removing the 'allownopasswords' or setting similar to that to allow me to enter with no pass.
At this point I decided to completely reinstall and use a password.
So I attempting to remove the packages I had used using some commands found here: How do I remove the LAMP stack so I can start over? & How do I remove the LAMP stack so I can start over?
I then reinstalled lamp-server, this time it showed no password entry and then I installed phpmyadmin.
Now when I goto localhost/phpmyadmin it just displays the config file, as if PHP is not installed.
I assume I am now missing some vital parts of the server.
I want to completely start afresh and install LAMP from scratch, how can I do this?
It would also be useful to know what the different passwords are for mySQL that it requests on installation, is it just 1 root user and password?
Thanks,
Thomas
  • 6,433
My preference is using apt/apt-get rather than tasksel.
Many times seems to fail for me + disallow simple customizations.
Destroying an entire LAMP Stack install can be a bit tricky.
You'll use apt-get purge $package to removed code + all config files.
Then use dpkg -l | grep $package to verify you've actually removed all traces of related packages.
Installing Apache-2.4.28 + PHP-5.6 covers how I install full lamp stacks for my hosting clients. Just change all occurrences of 5.6 to 7.1 to install latest PHP code.
