I'm not sure what the issue is, but I'm pretty sure something went seriously wrong in my MySQL installation. I have tried pretty much all of the solutions at the following links: How to repair corrupt package installation (mysql), How to completely delete MySQL for clean install, How do I uninstall MySQL completely?. But unfortunately, nothing has worked. When each of these solutions was tried, a common error was generated, which is as follows:
libmysqlclient20 : Depends: mysql-common (>= 5.7.20-1ubuntu16.04)
Breaks: libmysqlclient20:i386 (!= 5.7.20-1ubuntu16.04) but 5.7.20-0ubuntu0.16.04.1 is to be installed
libmysqlclient20:i386 : Depends: mysql-common:i386 (>= 5.5)
Breaks: libmysqlclient20 (!= 5.7.20-0ubuntu0.16.04.1) but 5.7.20-1ubuntu16.04 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
The whole error message and command is here:
sudo apt-get --yes purge mysql-apt-config mysql-common mysql-
community-server mysql-workbench-community mysql-client mysql-community-client mysql-server mythes-en-us
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
This error is particularly burdensome becaused dpkg has been acting up because of it, as well as apt-get. I am completely willing to get rid of MySQL if it means that I can get this error fixed.
Does anyone have advice on how to fix this?
