133
I am looking for a utility that will benchmark CPU performance under single and multi threaded instances. At present I have an old rig with a dual core CPU (E7500) at 3.6 Ghz and I am looking at replacing it with a quad core CPU (Q9400) at 3.2 Ghz. I want to see if I will notice a performance improvement with the extra 2 cores (albeit with a drop in core speed). I will clock the CPU's with the same FSB (400Mhz) and the cache size is the same per CPU (1.5MB) and for what its worth I have 4GB ram (with potential to upgrade to 6GB)
My son mainly uses the PC for playing TF2 (which I am trying to still get working under Linux) and I also use it for some video encoding (MP4 to DVD)
I am thinking that I could be better off with the quad core but any feedback would be appreciated.
fatso
  • 1,331
5 Answers5
166
Actually there is a a tool named sysbench.
You can install it with:
sudo apt-get install sysbench
To do CPU benchmarking you can use:
sysbench cpu run
This will run a single-threaded CPU benchmark. To use all cores, use:
sysbench --threads="$(nproc)" cpu run
Raja G
  • 105,327
  • 107
  • 262
  • 331
54
Old question (with no selected answer yet )
But I recently was looking for a tool available in multiple "distros" (Termux not really being a distro) including Ubuntu, and while the above mentioned packages are a common good choice, I read here: https://linuxhint.com/useful_linux_stress_test_benchmark_cpu_perf/ that 7-zip has a built-in benchmarking tool! And 7zip can be found in nearly every distros repository.
To run a single-thread benchmark: 7z b -mmt1
To run a multi-thread benchmark: 7z b
Results from my Pixel 2 phone:
7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=utf8,Utf16=on,HugeFiles=on,64 bits,8 CPUs LE)
LE
CPU Freq:  1509  2234  2434  2447  2433  2406  2430  2425  2400
RAM size:    3657 MB,  # CPU hardware threads:   8
RAM usage:    435 MB,  # Benchmark threads:      1
                       Compressing  |                  Decompressing
Dict     Speed Usage    R/U Rating  |      Speed Usage    R/U Rating
         KiB/s     %   MIPS   MIPS  |      KiB/s     %   MIPS   MIPS
22:       1666    99   1631   1621  |      30427   100   2608   2598
23:       1602    99   1644   1633  |      29815   100   2589   2581
24:       1517    99   1644   1632  |      29441   100   2595   2585
25:       1397    99   1607   1596  |      28748   100   2567   2559
Avr:              99   1632   1620  |              100   2590   2581
Tot:              99   2111   2100
45
Alternatively, one can use stress-ng. It has a CPU stress test as one of the many stress tests built into the tool. The cpu stress test contains many different CPU stress methods covering integer, floating point, bit operations, mixed compute, prime computation, and a wide range of computations.
Install using:
sudo apt-get install stress-ng
To see the cpu related stress methods use:
stress-ng --cpu-method which
To benchmark, for example, matrix product for 60 seconds on 4 CPU threads, use:
stress-ng --cpu 4 --cpu-method matrixprod  --metrics-brief --perf -t 60
stress-ng: info:  [15876] dispatching hogs: 4 cpu
stress-ng: info:  [15876] successful run completed in 60.00s (1 min, 0.00 secs)
stress-ng: info:  [15876] stressor      bogo ops real time  usr time  sys time   bogo ops/s   bogo ops/s
stress-ng: info:  [15876]                          (secs)    (secs)    (secs)   (real time) (usr+sys time)
stress-ng: info:  [15876] cpu              71657     60.00    239.60      0.00      1194.25       299.07
stress-ng: info:  [15876] cpu:
stress-ng: info:  [15876]            885,244,279,148 CPU Cycles                    14.75 B/sec
stress-ng: info:  [15876]          1,289,303,858,968 Instructions                  21.49 B/sec (1.456 instr. per cycle)
stress-ng: info:  [15876]            201,499,961,692 Cache References               3.36 B/sec
stress-ng: info:  [15876]                    790,424 Cache Misses                  13.17 K/sec ( 0.00%)
stress-ng: info:  [15876]            157,689,508,544 Branch Instructions            2.63 B/sec
stress-ng: info:  [15876]              1,232,539,732 Branch Misses                 20.54 M/sec ( 0.78%)
stress-ng: info:  [15876]              5,755,605,036 Bus Cycles                    95.92 M/sec
stress-ng: info:  [15876]            817,296,440,876 Total Cycles                  13.62 B/sec
stress-ng: info:  [15876]                      8,532 Page Faults Minor            142.19 sec
stress-ng: info:  [15876]                          0 Page Faults Major              0.00 sec
stress-ng: info:  [15876]                        220 Context Switches               3.67 sec
stress-ng: info:  [15876]                          0 CPU Migrations                 0.00 sec
stress-ng: info:  [15876]                          0 Alignment Faults               0.00 sec
yprez
  • 943
17
Phoronix Test Suite
This is an open source test suite licensed under the GPLv3:
Phoronix automates and standardizes the benchmarking of several real world use cases like compression, encryption and databases. Most tests benchmark open source software projects, but some also benchmark closed source software. They also host test results at: https://openbenchmarking.org which anyone can upload to, so you can compare test results with other different systems.
Since 18.04 there isn't a package on the official repos for it, so tested on Ubuntu 23.10 you just have install the dependencies:
sudo apt-get install php-cli php-xml
and then either:
  • download it from https://www.phoronix-test-suite.com/?k=downloads
    wget https://phoronix-test-suite.com/releases/phoronix-test-suite-10.8.4.tar.gz
    tar xfz phoronix-test-suite-10.8.4.tar.gz
  • git clone it:
    git clone https://github.com/phoronix-test-suite/phoronix-test-suite
and then in either case optionally add it to the PATH with:
export PATH="$PATH:$(pwd)/phoronix-test-suite"
PHP is needed because it is actually the main scripting language of the suite. These were different times altogether!
Until 18.04 there was a package for it, tested on Ubuntu 16.10:
sudo apt-get install phoronix-test-suite
Tested on version 10.8.4, we can list all tests with:
phoronix-test-suite list-all-tests
The first few lines are:
pts/3dmark                  3DMark Wild Life Extreme        Graphics
pts/ai-benchmark            AI Benchmark Alpha              System
pts/aircrack-ng             Aircrack-ng                     Processor
The last column categorizes the main thing being benchmarked, some possible values are:
  • Processor: CPU
  • Graphics: GPU
  • Memory: RAM
  • Network
  • Disk
  • System: likely mean a mixture of multiple above categories
Let's try a self explanatory processor bound one which basically benchmarks GCC:
phoronix-test-suite install pts/build-linux-kernel
phoronix-test-suite run pts/build-linux-kernel
First it asks some annoying configuration questions, first which kernel configuration we want to build, I select 1 for defconfig:
Timed Linux Kernel Compilation 6.1:
    pts/build-linux-kernel-1.15.0
    Processor Test Configuration
        1: defconfig    [Default Kernel Build]
        2: allmodconfig [This option is *much* more time consuming...]
        3: Test All Options
        ** Multiple items can be selected, delimit by a comma. **
        Build: 1
then:
Would you like to save these test results (Y/n):
Enter a name for the result file:
Enter a unique name to describe this test run / configuration:
New Description:
and then it proceeds to build the Linux kernel a bunch of times.
How to automate answering those questions was asked at: https://stackoverflow.com/questions/28581447/how-to-skip-phoronix-test-suite-inital-questions It is quite annoying really.
Running the test so many times is a bit excessive for a casual run, so let's limit it to a single run with FORCE_TIMES_TO_RUN=1:
FORCE_TIMES_TO_RUN=1 phoronix-test-suite run pts/build-linux-kernel
After dumping my system's configuration, at the end we see:
    pts/build-linux-kernel-1.15.0 [Build: defconfig]
    Test 1 of 1
    Estimated Trial Run Count:    1
    Estimated Time To Completion: 9 Minutes [04:37 UTC]
        Running Pre-Test Script @ 04:29:14
        Started Run 1 @ 04:29:27
        Running Post-Test Script @ 04:32:23
Build: defconfig:
    173.449
Average: 173.449 Seconds
Samples: 1
so the test result was how long it took to build the kernel, which was 173.449 seconds on my system.
We can see how that compares with other systems at: https://openbenchmarking.org/test/pts/build-linux-kernel I'm running an AMD Ryzen 7 PRO 7840U on a Lenovo ThinkPad P14s, and for that CPU the public results were 129 +/- 9. So sadface, there seems to be something wrong with my system, as I'm considerably slower than those tests, maybe a performance mode issue? Setting to High Performance But at least this illustrates the awesome value of having public results available!
By tweaking "Analyze Test Configuration" we can also see:
Let's try another benchmark, how about stress-ng which was mentioned in another answer with configuration 1: CPU Stress
printf 1 | FORCE_TIMES_TO_RUN=1 phoronix-test-suite batch-run pts/stress-ng
and this time we see:
Stress-NG 0.16.04:
    pts/stress-ng-1.11.0 [Test: CPU Stress]
    Test 1 of 1
    Estimated Time To Completion: 1 Minute [12:15 UTC]
        Started Run 1 @ 12:14:56
Test: CPU Stress:
    22191.17
Average: 22191.17 Bogo Ops/s
Samples: 1
where the test results is 22191.17 Bogo Ops/s, which is how stress-ng reports its output, and means just how many operations it did in a given amount of time. So we see that this is a different type of test, which rather than benchmarking the time to completion of a task rather set a timer and ran as many times as possible.
While it runs, I try to observe the final commands it is running with:
ciro     2117375  0.0  0.0   2780  1920 pts/11   S+   12:20   0:00 /bin/sh /home/ciro/down/phoronix-test-suite/phoronix-test-suite batch-run pts/stress-ng
ciro     2117388  0.0  0.0   2780  1792 pts/11   S+   12:20   0:00 sh -c  php /home/ciro/down/phoronix-test-suite/pts-core/phoronix-test-suite.php batch-run pts/stress-ng
ciro     2117673  0.0  0.0   2784  1792 pts/11   S+   12:20   0:00 /bin/sh ./stress-ng -t 30 --metrics-brief --cpu -1 --cpu-method all --no-rand-seed
ciro     2117674  0.0  0.0  39132  6528 pts/11   SL+  12:20   0:00 ./stress-ng -t 30 --metrics-brief --cpu -1 --cpu-method all --no-rand-seed
A bit more digging shows that the shell script is something from Phoronix: ~/.phoronix-test-suite/installed-tests/pts/stress-ng-1.11.0 which simply does:
#!/bin/sh
cd stress-ng-0.16.04
./stress-ng $@ > $LOG_FILE 2>&1
echo $? > ~/test-exit-status
where stress-ng is the final executable.
Test suites
Besides individual tests, Phoronix Test Suite also has the concept of test suites, which are just groups of tests. TODO how to list all test suites? I tried:
phoronix-test-suite list-available-suites
but it does not contain all suites. Notably, it is missing pts/cpu, which contains several CPU benchmarks. Note that this will be slow and download a bunch of test executables
Running a suite is similar to running a single test:
phoronix-test-suite install pts/cpu
phoronix-test-suite run pts/cpu
We can see which tests are contained in a suite with:
phoronix-test-suite info pts/cpu
which contains a list such as:
Contained Tests:
                    Rodinia      Test: OpenMP CFD Solver
                    Rodinia      Test: OpenMP LavaMD
                    NAMD
                    Stockfish
                    x264         Video Input: Bosphorus 1080p
                    x264         Video Input: Bosphorus 4K
so we quickly understand that is it picking certain configs of certain tests. TODO: is there a way to list the actual test identifiers, e.g. pts/rodinia and so on? One way is to look at: https://openbenchmarking.org/suite/pts/cpu
Another one of interest for CPU benchmarking which I found by randomly doing find is:
phoronix-test-suite info pts/cpu-massive
which contains a whopping 373 tests.
Upload a test result
First we create an account: https://openbenchmarking.org/register
TODO haven't managed to login yet. Confirmation email didn't arrive? I'll try again later some day.
File structure
Finally, let's have a look at the file that Phoronix keeps around:
ncdu ~/.phoronix-test-suite/
shows:
  167.1 MiB [###########################] /installed-tests
   44.1 MiB [#######                    ] /test-profiles
    2.9 MiB [                           ] /test-results
    1.1 MiB [                           ] /openbenchmarking.org
  636.0 KiB [                           ] /test-suites
   12.0 KiB [                           ]  core.pt2so
e   4.0 KiB [                           ] /modules-data
e   4.0 KiB [                           ] /download-cache
    4.0 KiB [                           ]  user-config.xml
    4.0 KiB [                           ]  graph-config.json
    4.0 KiB [                           ]  phoronix-test-suite-dependencies.log
    0.0   B [                           ]  phoronix-test-suite-benchmark.log
installed-tests contains source code and prebuilts, e.g. the Linuxk kernel build only has the source code txz:
--- /home/ciro/.phoronix-test-suite/installed-tests/pts/build-linux-kernel-1.15.0 -------------
  128.5 MiB [###########################]  linux-6.1.tar.xz
The build dir was either deleted, or lies outside of of ~/.phoronix-test-suite.
stress-ng has the packed source, the unpacked source, and the built executable:
--- ~/.phoronix-test-suite/installed-tests/pts/stress-ng-1.11.0 -
   34.8 MiB [###########################] /stress-ng-0.16.04
    3.7 MiB [##                         ]  stress-ng-0.16.04.tar.gz
Another interesting directory is ~/.phoronix-test-suite/test-results which stores run results under:
  • Enter a name for the result file: if you entered that interactively
  • a datetime such as 2023-12-23-0414 when running with batch-run
11
If you don't have root permissions (e.g. managed web servers)
Measure single core:
-bash-4.2$ time cat </dev/urandom | head -c 1G | gzip >/dev/null
real 0m43.011s user 0m42.608s sys 0m8.819s
Measure all cores:
-bash-4.2$ time cat </dev/urandom | head -c 1G | pigz >/dev/null
real 0m13.870s user 0m45.988s sys 0m6.803s
If you already have pv but don't feel like installing special benchmarking software it's even more straightforward
a@a-virtual-machine:~$ pv </dev/urandom | gzip >/dev/null
 149MiB 0:00:04 [37.5MiB/s]
a@a-virtual-machine:~$ pv </dev/urandom | pigz >/dev/null
 348MiB 0:00:02 [ 173MiB/s]
