57
I have seen it before. I am just wondering what exactly does it do?
From man apt-get:
   -f, --fix-broken
       Fix; attempt to correct a system with broken dependencies in place. This
       option, when used with install/remove, can omit any packages to permit APT
       to deduce a likely solution. If packages are specified, these have to
       completely correct the problem. The option is sometimes necessary when
       running APT for the first time; APT itself does not allow broken package
       dependencies to exist on a system. It is possible that a system's dependency
       structure can be so corrupt as to require manual intervention (which usually
       means using dselect(1) or dpkg --remove to eliminate some of the offending
       packages). Use of this option together with -m may produce an error in some
       situations. Configuration Item: APT::Get::Fix-Broken.
Isaiah
  • 60,750
Here's where I found it very useful. I ran a dpkg command to install a couple of .deb packages, but the install failed because some dependencies were missing.
I then ran
apt-get -f install
and it installed exactly the dependencies that were needed. I was then able to re-run my dpkg command and everything worked.
Chad
  • 573
  • 14
