Below are the results of trying to install Steam in 16.10.
sudo apt-get install steam
[sudo] password for micah:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 gcc-5-multilib : Depends: libc6-dev-i386 (>= 2.11) but it is not going to be installed
 libc6-dev-x32 : Depends: libc6-dev-i386 (= 2.23-0ubuntu5) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
How do I solve these unmet dependencies?
Zanna
  • 72,312
Steam has two i386 architecture unmet dependency packages depending on GNU C Library: 32-bit development libraries for AMD64 (libc6-dev-i386). To correct the unmet dependencies, open the terminal and type:
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get -f install
karel
  • 122,292
  • 133
  • 301
  • 332
-2
Try running this command:
apt-get --fix-broken install
This attempts to fix broken dependencies. (--fix-broken is the same as -f.)
Eliah Kagan
  • 119,640
