I am having problem on this error "error while loading shared libraries: libz.so.1: " . so I install this package apt-get install zlib1g:i386 but this is th result.
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 libssl-dev : Depends: libssl1.0.0 (= 1.0.2g-1ubuntu4.8) but 1.0.2g-1ubuntu4.10 is to be installed
              Depends: zlib1g-dev but it is not going to be installed
              Breaks: libssl-dev:i386 (!= 1.0.2g-1ubuntu4.8) but 1.1.0g-2.1+ubuntu16.04.1+deb.sury.org+1 is to be installed
 libssl-dev:i386 : Breaks: libssl-dev (!= 1.1.0g-2.1+ubuntu16.04.1+deb.sury.org+1) but 1.0.2g-1ubuntu4.8 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
This is my operating system
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.3 LTS
Release:        16.04
Codename:       xenial
I tried apt-get -f install and this is the result
(Reading database ... 129365 files and directories currently installed.)
Preparing to unpack .../libssl-dev_1.1.0g-2.1+ubuntu16.04.1+deb.sury.org+1_amd64.deb ...
Unpacking libssl-dev:amd64 (1.1.0g-2.1+ubuntu16.04.1+deb.sury.org+1) over (1.0.2g-1ubuntu4.8) ...
dpkg: error processing archive /var/cache/apt/archives/libssl-dev_1.1.0g-2.1+ubuntu16.04.1+deb.sury.org+1_amd64.deb (--unpack):
 trying to overwrite shared '/usr/include/openssl/e_os2.h', which is different from other instances of package libssl-dev:amd64
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Thank you in advance.
jemz
  • 143
Although there is no question posted, I assume you want to move forward with apt-get install zlib1g:i386.
Do sudo apt-get -f install, similar to what was suggested. That should fix your dependency system.
What exactly does sudo apt-get -f install do?
