259
I'm just talking about the standard KDE desktop. After a while (many days) of running the task bar stops working properly. This is due to some sort of undiagnosed bug but that's really not my boggle at the moment. It's fixed as soon as I log out and in again.
I have to close everything and ongoing processes like virtual machines have to shut down. It's a big pain. It typically means I put up with a bit of flickering for many days.
Is there a way to just reload the desktop without bombing all the running applications?
Oli
  • 299,380
11 Answers11
410
In KDE 4, you can do:
killall plasma-desktop #to stop it
kstart plasma-desktop #to restart it
In KDE 5 use:
killall plasmashell #to stop it
kstart plasmashell #to restart it
In KDE > 5.10 use:
kquitapp5 plasmashell
kstart5 plasmashell
Sometimes plasmashell is not responding so kquitapp5 fails after a timeout and you have to get back to killall. So in a nutshell, I would do :
# For KDE 4
killall plasma-desktop && kstart plasma-desktop
For KDE 5 < 5.10
killall plasmashell && kstart plasma-desktop
For KDE > 5.10
kquitapp5 plasmashell || killall plasmashell && kstart5 plasmashell
Remarks :
  1. If you are not sure which KDE version your run, kinfocenter --version will tell you.
  2. you can skip the kquitapp5 plasmashell || part if you don't want to be stuck in the timeout when plasmashell is not responding.
ChrisAga
  • 1,079
Korcia
  • 4,745
86
In KDE5 use "kstart plasmashell" to restart the plasmashell as a service instead of plasmashell &. If you use it that way it 's run as an independed service not connected to the current terminal session (meaning you can close the terminal without the process getting terminated). TLDR:
KDE5 (in Terminal):
killall plasmashell
kstart plasmashell
81
Well I didn't expect this to work (and it's not exactly what the question asks for) but pressing Alt+F2 and running:
kwin --replace
This reloads KDE's compositor and that seems to fix the flickering. I guess it's a factor into my particular issue.
Oli
  • 299,380
12
The window manager kwin is responsible for moving around windows, etc. That can be restarted by this:
kstart kwin --replace
The kstart prefix is just to not run it as a subprocess in the current terminal, such that you can close the terminal afterwards.
plasmashell is responsible for the background and other shell things. Restarting that should work like this:
killall plasmashell
kstart plasmashell
Note that this did not bring back the menu for me.
Also, interestingly, this again breaks kwin for me, i.e. I'm not able to move windows around anymore. On console, I get sth like QXcbConnection: XCB error: 3 (BadWindow), sequence: ..., resource id: ..., major code: 15 (QueryTree), minor code: 0.
Albert
  • 2,817
Some times ago, the plasma desktop started to have issues when I have attached a USB hub with USB-C and a second monitor. The window panel does not show any icons.
When I restart plasma by
plasmashell --replace &
Everything works fine again. My current plasma version is 5.26.4.
stollr
  • 163
I looked this up because I had an issue where I couldn't open any KDE settings menus, but I didn't really want to reboot or log out. I found that the best way to do it (in KDE 5 at least) is by using krunner (Alt+F2) to killall plasmashell then immediately afterwards, plasmashell. I tried doing it in a Konsole window, using killall plasmashell and then plasmashell & and this worked, but as soon as I closed the Konsole window, plasma would close as well. Even though you seemed to resolve your issue, I figured I would post it for people coming along in the future needing to restart plasma.
In KDE 4, just replace plasmashell with plasma-desktop
Two KDE developers wrote:
If you’re using Plasma’s systemd startup integration — which you probably are since it’s on by default for distros that ship systemd — the correct way to restart Plasma is systemctl restart --user plasma-plasmashell
-- https://discuss.kde.org/t/how-to-restart-plasma-panel/15490/14 , https://pointieststick.com/2024/09/20/this-week-in-plasma-polishing-like-mad
Asensi
  • 75
OK .. I am running OpenSuse Leap 15.1 running KDE5 Plasma. Periodically, my X environment is corrupted (after about 24 hours of leaving my machine running) and I get "KLauncher could not be reached via D-Bus. Error when calling start_service_by_desktop_path: Not connected to D-Bus server"
The result of this is that while my desktop still functions I can't launch any applications which use KLauncher -- very annoying. (NOTE: also my xwindows vncserver appears to launch 99 instances of display windows I could attach to -- which isnt right -- I havent corrected this yet but I will). However, I FOUND the answer to the above issue to restart KDE 5 Plasma in my environment without a reboot:
1) killall plasmashell 2) kstart5 plasmashell kwin
This restarts everything as if the system is freshly booted. Hope this helps
Thanks
I find I'm always having trouble with ksycoca5, and this seems to be the reason plasmashell gets in a strop, and also stops plasmashell restarting. To solve this I did:
$ mv ~/.cache/ksycoca5* /tmp
$ killall plasmashell buildksycoca5; kstart plasmashell
I also tried something like:
killall plasmashell; kstart plasmashell
Or even this:
killall plasmashell; kwin --replace && kstart plasmashell
But, for, unknown reasons, it didn't work.
Plasma desktop restarting began to work after I added sleeps among the commands:
killall plasmashell ; sleep 3 ; kwin --replace ; sleep 5 ; kstart plasmashell
Finally, I've noticed that, when type 'kwin|plasma' in KSysGuard filter field, it reports that after killing plasmashell, such *.so files are still present: desktop.so, file.so. We must kill them too. Otherwise, we'll have copies of that files after each restart.
So, the final plasma desktop restarting commands are:
killall plasmashell desktop.so file.so ; sleep 5 ; kwin --replace ; sleep 5 ; kstart plasmashell
In KDE4 I find the memory usage ramps up to around a gigglebite pretty rapidly because opening programs progressively uses more RAM, but closing them does not release it. This is in Mint 17.3 with KDE but seems to affect pretty well ALL KDE plasma 4 systems.
I got sick of logging in and out, or using ALT + F2 to kill and restart plasma. So now I just have a script (set as executable) sitting on the panel..
#!/bin/bash
plasma-desktop &
Click on the icon and plasma does a close and restart over about 15 seconds or so. I can still use open programs on whichever virtual desktop I am currently using while plasma is restarting.
RossD
  • 29
