I would like your help solving this issue. I recently installed Kubuntu 20.04 and sometimes (randomly, but specially after shutting down abruptly) the system gives no GUI after login (I'm not sure how to call it properly :) ... )
I'm gonna add some pictures to clarify what I'm saying.
First Image - Login screen
Second Image - After entering password
Third Image - I can enter the terminal
Fourth Image - Hitting ALT + Space Bar
So, it gets to login screen as usual. After entering the password a black screen appears, with only a grey line at the bottom. Hitting CTRL + ALT + T enters the terminal. Hitting ALT + Space Bar shows only a grayish rectangle at the top of the screen. Entering $shutdown -r now restarts the computer and the error is gone. I can use it perfectly.
I can reproduce this problem by pressing down the power button until the system is forced to shutdown. When it boots again, the error is there.
The computer specs are: Lenovo S145-15API AMD Ryzen 7 8GB RAM 256GB SSD 1920x1080 No dedicated GPU
Linux DLinux 5.4.0-28-generic #32-Ubuntu SMP Wed Apr 22 17:40:10 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Thank you!
The same happens to me. I believe it will be fixed soon but in the meanwhile, I found (by googling) the following solution. Open Konsole, and issue the next commands as a normal user:
  • killall plasmashell
  • plasmashell &
  • disown
Then, you can freely close the Konsole window.
vramos
