I use Kubuntu. I noticed something weird. KDE Plasma that happened to install updates but when I started the system I got some black and white effects, missing menu items, etc.
I made this YouTube video to show what I mean.
Everything is working okay (effects of icons, maximize etc), but I don't have a Desktop, and I can't right click on desktop.
I tried
  • reinstalling whole kde plasma (that includes kubuntu +kde plasma, I using this setup on recovery)
  • tried to uninstall fully complete and checked the files is here or no.
  • tried to modify the kscreen (a folder including the conf)
plasmashell failed to start. Error :
dragonpc@dragonpc-H110M-DS2:~$ plasmashell
org.kde.plasmaquick: Applet preload policy set to 1
Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/code/LayoutManager.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/LayoutManager.js")
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/code/FolderTools.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderTools.js")
trying to show an empty dialog
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:294:17: QML Text: Binding loop detected for property "width"
org.kde.plasmaquick: New Applet  "Application Launcher" with a weight of 92
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Both point size and pixel size set. Using pixel size.
org.kde.plasmaquick: New Applet  "Digital Clock" with a weight of 12
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.panel/contents/code/LayoutManager.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/LayoutManager.js")
Failed to find service for Unity Launcher "application://Skype.desktop"
org.kde.plasmaquick: New Applet  "Audio Volume" with a weight of 0
org.kde.plasmaquick: New Applet  "Clipboard" with a weight of 0
org.kde.plasmaquick: New Applet  "Device Notifier" with a weight of 0
org.kde.plasmaquick: New Applet  "KDE Connect" with a weight of 0
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/code/uiproperties.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/uiproperties.js")
org.kde.plasmaquick: New Applet  "Notifications" with a weight of 0
org.kde.plasmaquick: New Applet  "Printers" with a weight of 0
org.kde.plasmaquick: New Applet  "Updates" with a weight of 0
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/code/logic.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/logic.js")
org.kde.plasmaquick: New Applet  "Battery and Brightness" with a weight of 0
file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:53:39: Unable to assign [undefined] to int
networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "AllDevices"
networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Capabilities"
networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckAvailable"
networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "ConnectivityCheckEnabled"
networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "Devices"
networkmanager-qt: void NetworkManager::NetworkManagerPrivate::propertiesChanged(const QVariantMap&) Unhandled property "GlobalDnsConfiguration"
networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "LldpNeighbors"
networkmanager-qt: virtual void NetworkManager::DevicePrivate::propertyChanged(const QString&, const QVariant&) Unhandled property "Real"
org.kde.plasmaquick: New Applet  "Networks" with a weight of 64
Warning: all files used by qml by the plasmoid should be in ui/. The file in the path "file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/code/logic.js" was expected at QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js")
org.kde.plasmaquick: New Applet  "Bluetooth" with a weight of 0
org.kde.plasmaquick: Delayed preload of  "Application Launcher" after 0.508 seconds
KAStatsFavoritesModel::setFavorites is ignored
org.kde.plasmaquick: Applet "Application Launcher" loaded after 78 msec
libpng warning: iCCP: known incorrect sRGB profile
QSGSimpleMaterialShader does not implement 'uniform highp mat4 qt_Matrix;' in its vertex shader
KCrash: Attempting to start /usr/bin/plasmashell from kdeinit
sock_file=/run/user/1000/kdeinit5__0
KCrash: crashing... crashRecursionCounter = 2
KCrash: Application Name = plasmashell path = /usr/bin pid = 13544
KCrash: Arguments: /usr/bin/plasmashell
KCrash: Attempting to start /usr/lib/x86_64-linux-gnu/libexec/drkonqi from kdeinit
QSocketNotifier: Invalid socket 8 and type 'Read', disabling...
QSocketNotifier: Invalid socket 17 and type 'Read', disabling...
QSocketNotifier: Invalid socket 9 and type 'Read', disabling...
[1]+  Stopped                 plasmashell
Zanna
  • 72,312
this is not an answer (yet), so I make it a community wiki.
a few things, which probably don't fix your problem, but should be noted:
  • use kstart plasmashell instead of just plasmashell [1]
  • stop all other plasmashell processes using killall plasmashell before starting it again [1]
  • I can see the line [1]+ Stopped plasmashell at the end of your log. it means you've ”stopped“ (!) plasmashell (by pressing Ctrl+Z) instead of TERMinating it. if you start plasmashell without kstart, use Ctrl+C to terminate it.
In short: when problems with the plasma shell occurr, try if restarting it [1] helps.
[1] see Can I restart the KDE Plasma Desktop without logging out?
myrdd
  • 422
