The temporary fix - overriding the initial mounting of the root.disk to rw (read/write) instead of ro(read-only) is good. It's the only way to boot Wubi after a 14.04 install (or upgrade).
However, there is a better long term fix than permanently modifying the mount to read/write. It's best to modify the way the loop device is created in order to allow remounting as read-write. This will then allow you to use recovery mode.
Modify the file /usr/share/initramfs-tools/script/local as shown (one line removed, three added):
--- /home/bcbc/local 2014-11-19 20:25:12.274837304 -0800
+++ /usr/share/initramfs-tools/scripts/local 2014-11-19 20:28:37.990832807 -0800
@@ -143,7 +143,9 @@
modprobe ${FSTYPE}
# FIXME This has no error checking
- mount ${roflag} -o loop -t ${FSTYPE} ${LOOPFLAGS} "/host/${LOOP#/}" ${rootmnt}
+ loopdev=`losetup -f`
+ losetup ${loopdev} "/host/${LOOP#/}"
+ mount ${roflag} -t ${FSTYPE} ${LOOPFLAGS} ${loopdev} ${rootmnt}
if [ -d ${rootmnt}/host ]; then
mount -o move /host ${rootmnt}/host
After making the change, update the initial ramdisk:
sudo update-initramfs -u
For additional information, and credit for the fix see: https://code.launchpad.net/~noorez-kassam/ubuntu/utopic/initramfs-tools/fix-for-1317437/+merge/219927
Caution: obviously if you make some typos when applying this fix it may prevent your install from booting. So proceed with caution. And if unsure, use the easier Grub override. Make sure you use the ` quote, not ' for the loopdev= line.
If you attempt this and run into problems, there are a couple of things you can try:
- If you have more than one kernel, go to the Recovery menu and select an older kernel (with it's own initramfs).
- You could backup the
initramfs (before updating), and then copy it over the bad one from a live DVD/USB.
- You could rebuild the
initramfs in a chroot, but this is a bit involved.
If it's a fresh install, then reinstalling is your best option.
