This is my first post on askubuntu. So, if i break any rules, then please do tell me.
I am using Windows 10, on a 4gb ram,64 bit environment. Previously when I used to install Ubuntu then I used to install it with wubi. So, I didn't have to make extra partitions or so. But,now as I came to know from some of the post on this forum that wubi is no longer available for installation of ubuntu. Is it even possible to install ubuntu 15.10 in the same way as wubi did, but manually, or any other software.
While using wubi, if ubuntu had problems, I could just simply uninstall ubuntu from the control panel. And nothing else. So, I don't want to make extra partition to install ubuntu.
Steps Tried:
I installed ubuntu 13.10 using wubi. And then upgraded the ubuntu to latest version. After upgrade when it restarted, there was mounting problem,So again had to uninstall. Is there way to solve this mounting.
Any Help/Explaination would be nice.
See answers of Ubuntu 14.04 not booting after error message. /tmp could not be mounted
I installed 15.10 with Wubi without any problems. There is no official Wubi solution (besides to remove it from isos) but community supported versions still exist. See solutions of other Wubi users like this one.
ngng
  • 463
If you're not doing anything terribly resource intensive and just want to play around with it (which is implied by the fact you're wanting to use Wubi instead of giving it its own partition outside of Windows), you could just install Ubuntu in a virtual machine.
I use Oracle VirtualBox (www.virtualbox.org) to create and manage virtual machines, but there are others out there that are free.
If your concern is for your Windows partition, you can always just use GParted Live to resize your Windows partition back to full if you install Ubuntu and change your mind about it later.
You can find a little more information about the state of Wubi at this askubuntu page: Windows installer for Ubuntu 14.04 LTS onwards
Gerowen
  • 1,468
According to Rinzwind's answer on Windows installer for Ubuntu 14.04 LTS onwards question , WUBI is still supported but it's not recommended to use.
As far as Ubuntu installation is concerned ( or really any OS ) a hard drive has to be partitioned. That isn't exclusive to WUBI - any installer does that - Windows, Mac , or Linux. New Ubuntu installer does the same thing. An operating system needs to live somewhere on the hard drive.
If you don't want to partition a hard drive, there's three options: have another hard-drive with Ubuntu, install Ubuntu as the only OS on the drive (which is still partitions the drive to only have two partitions - Ubuntu and swap ), and use virtual machine. The last one is the best - I have 4 different virtual machines in VirtualBox. If anything goes wrong - just delete the virtual machine and start over.
Follow this guide on how to install Ubuntu in VirtualBox:
How to install Ubuntu on VirtualBox?
