109
I have 2 HDDs in my PC. Ubuntu is turning off the secondary HDD very quickly after about 15 minutes, which is short for me. I need to control this time. How can I do it?
I tried GNOME power management but did not find it useful.
Braiam
  • 69,112
user16295
  • 1,091
14 Answers14
90
Have a look at hdparm.
From the manual (man hdparm on the command line):
-S     Put the drive into idle (low-power) mode,  and  also  set  the  standby  (spindown)
       timeout  for  the  drive.  This timeout value is used by the drive to determine how
       long to wait (with no disk activity) before turning off the spindle motor  to  save
       power.   Under  such  circumstances,  the  drive  may take as long as 30 seconds to
       respond to a subsequent disk access, though most  drives  are  much  quicker.   The
       encoding  of  the  timeout  value  is  somewhat  peculiar.   A  value of zero means
       "timeouts are disabled": the device will  not  automatically  enter  standby  mode.
       Values  from  1  to  240  specify  multiples of 5 seconds, yielding timeouts from 5
       seconds to 20 minutes.  Values from 241 to 251 specify from 1 to  11  units  of  30
       minutes,  yielding timeouts from 30 minutes to 5.5 hours.  A value of 252 signifies
       a timeout of 21 minutes. A value  of  253  sets  a  vendor-defined  timeout  period
       between  8  and  12 hours, and the value 254 is reserved.  255 is interpreted as 21
       minutes plus 15 seconds.  Note that some  older  drives  may  have  very  different
       interpretations of these values.
So:
sudo hdparm -I /dev/sdb | grep level
will show the current spindown value, for example:
Advanced power management level: 254
From the manual, 254 is reserved, so I expect it to be Ubuntu's default (can anyone confirm/expand on this please?).
Example:
  • sudo hdparm -S 25 /dev/sdb = spindown after 25*5 seconds.
  • sudo hdparm -S 245 /dev/sdb = spindown after (245-240)*30 minutes.
Rinzwind
  • 309,379
68
Disk Utility -> select HDD drive -> click on the "More actions..." icon on the top right corner -> Drive settings...
Mine is looks like this: screenshot
guntbert
  • 13,475
Ray
  • 906
44
If you're interested on do the hdparm's setting persistent between reboots, instead of adding it to the crontab, you can use the /etc/hdparm.conf. I have the following, note the use of capital S, not lowercase:
command_line {
    hdparm -S 25 /dev/disk/by-uuid/f6c52265-d89f-43a4-b03b-302c3dadb215
Add that line replacing the UUID by yours, or also you may specify the device using /dev/sdX format. You can find out your disk's UUID with the command sudo blkid.
Eliah Kagan
  • 119,640
30
  1. Find your disk's UUID.
    sudo lsblk --output NAME,FSTYPE,LABEL,UUID,MODE
  2. Edit /etc/hdparm.conf
    sudo -H gedit /etc/hdparm.conf  # Be careful from now on
  3. Look for spindown-time or your disk settings section.
    /dev/disk/by-label/4TB {
        spindown_time = 1200
  4. I prefer to refer to the disk by UUID which remains the same across different installations (unless you change it in the HW itself).
    /dev/disk/by-uuid/91e32677-0656-45b8-bcf5-14acce39d9c2 {
  5. If the init script causes boot problems, you can pass nohdparm on the kernel command line, and the script will not be run.
14
After spending hours and hours, I discovered that my Western Digital drive do not support hdparm -S command, no matter idle3 attribute value (google: idle3ctl). It is common problem with WD drives.
But I'm pleased to announce that hd-idle (http://hd-idle.sourceforge.net/) works flawlessly.
If installed from dpkg-built package (see the Installation notes), it creates daemon on both Ubuntu and Debian (config is in /etc/default/hd-idle). Works well after resuming from hibernation as well.
mc default # ps aux | grep hd-idle | grep -v grep | cut -c 66- ; for f in [a-d] ; do hdparm -C /dev/sd$f | grep -v "^$" ; done
/usr/sbin/hd-idle -i 1800 -a sdc -i 600 -a sdd -i 60 -l /var/log/hd-idle.log
/dev/sda:
 drive state is:  active/idle
/dev/sdb:
 drive state is:  standby
/dev/sdc:
/dev/sdd:
I add something like:
@reboot sudo hdparm -S244 /dev/disk/by-uuid/71492809-e463-41fa-99e2-c09e9ca90c8e  > /dev/null 2> /dev/null
to root's crontab. Using uuid is better I think because sda/sdb etc. seems to change with every reboot
muru
  • 207,228
I discovered that the spindown behavior of Samsung HD204UI depends on the APM level (hdparm -B). If the APM level is 127, the spindown timeout is 10 s. If the APM level is 150, the spindown timeout is defined by the -S option.
beroal
  • 159
An important note: unlike the main answer, it seems that
# Advanced power management level: 254
does not show the current spindown value (that we can set with hdparm -S, as desired by OP), but rather displays the value set with hdparm -M:
hdparm -M 128   # Set acoustic management to 'quiet'
hdparm -M 254   # Set acoustic management to 'fast'
Basj
  • 201
In Ubuntu 14.04
Disks > highlight drive > click the gear in the upper right hand corner > Drive Settings > now you have Standby, APM, AAM and Write Cache settings in an easy to use GUI!
on ubuntu 18.04 to 20.04, you can change drive setting standby timeout at:
search Disks in the launcher > select your disk > click on ⋮ at menu bar next to minimize the window button > Drive Settings > use slider to set timeout
Screenshot on ubuntu 20.04
WSMathias9
  • 133
I had no luck with hdparm on an external HDD mounted in a USB enclosure, which I use to serve media with minidlna.
I came across an idea from here: https://serverfault.com/questions/562738/keeping-usb-backup-drive-from-sleeping-while-mounted
Best results come from using the disk's uuid, which you can find with:
sudo blkid
The following method does require root access, but so does hdparm. This uses crontab to read a random block from the drive every 5 minutes and ignores all messages. To make sure you have the right UUID, test it on the command line like this (make sure you use your desired UUID, not this one):
sudo dd if=/dev/disk/by-uuid/f01df4b5-6865-476a-8d3b-597cbd886d41 of=/dev/null count=1 skip=$RANDOM
You should see output like this:
1+0 records in
1+0 records out
512 bytes copied, 0.000738308 s, 693 kB/s`
To suppress this message, which could end up getting written somewhere, potentially the / filesystem (which is on an SSD in my case), below is what I'm using in the root crontab. You get there with
sudo crontab -e
Then, under the comments:
*/5 * * * * bash -c 'dd if=/dev/disk/by-uuid/f01df4b5-6865-476a-8d3b-597cbd886d41 of=/dev/null count=1 skip=$RANDOM' >/dev/null 2>&1
Hope this helps someone else with similar issues. Unfortunately, this still gets written to the syslog, but there are potentially ways to suppress that; see this ServerFault post.
[edit] 2017-01-07 09:02:
I was able to suppress these messages by editing /etc/rsyslog.d/50-default.conf to change this line:
*.*;auth,authpriv.none -/var/log/syslog
to this:
*.*;cron,auth,authpriv.none -/var/log/syslog
Unfortunately, this suppresses all cron messages; I could not get cron to redirect logging off the root filesystem (which is on an aging SSD in my case, so I want to limit writes), but as this is just a home server, I am probably not missing out on much. Would definitely not recommend this strategy for a production machine.
I have discovered that
sudo hdparam -S 0 /dev/sda1
on my disk gives this output:
setting standby to 0 (off)
Greenonline
  • 2,182
Use SMART Monitoring Tools smartctl to Change Standby Time
If you have SMART Monitoring Tools installed, your drive supports SMART (which it usually does), and your drive is SATA or ATA, you can use the smartctl program with the -s option flag to change a setting on a drive. Here is an excerpt from the smartctl manual page describing the behavior of the standby timer drive setting:
A value of 0 or 'off' disables the standby timer.  Values
from 1 to 240 specify timeouts from 5 seconds to 20 minutes
in 5 second increments.  Values from 241 to 251 specify
timeouts from 30 minutes to 330 minutes in 30 minute
increments.  Value 252 specifies 21 minutes.  Value 253
specifies a vendor specific time between 8 and 12 hours.
Value 255 specifies 21 minutes and 15 seconds.  Some drives
may use a vendor specific interpretation for the values.
Usage Examples
For example, this sets the standby timer to 20 minutes:
smartctl /dev/sdx -s standby,240
...and this command disables the standby timer to immediately spin the disk down, which is useful for preventing damage to the drive if you need to physically move it:
smartctl /dev/sdx -s standby,0
Notes
  • Remember that the target device should be the device itself and not a partition on that device, i.e. /dev/sda instead of /dev/sda1.
  • Keep in mind that some drives might have vendor specific behavior in relation to the standby setting.
  • To consistently change the settings of a specific disk, such as in a script that runs at boot, you can use the mapped UUID link of the disk within /dev/disk/by-uuid.
On Debian, with WD drives, I find that setting any level with hdparm -S results in the drive returning a level 254 on subsequent hdparm -I. So I'm really not sure if they're spinning down or not. I think they are still spinning down.
These drives are on a server array, and I really don't want them to ever spin down. In the past I've kludged this by setting a cron job to update a file every few minutes.
