13
I am able to spindown my SATA HDDs by using
sudo hdparm -y /dev/sdc
The state shown by
sudo hdparm -C /dev/sdc
changes from active/idle to standby (and I can hear the HDD spin down).
However, using
sudo hdparm -S5 /dev/sdc
doesn't spin down the drive after 5*5 = 25secs.
Some additional information:
  • AHCI is enabled.
  • I am using Western Digital Green drives.
  • APM_level = not supported
  • Filesystem is ext4
Edit: This question is not a duplicate to How can I control HDD spin down time? because it addresses Western Digital Green drives, which will not work with hdparm.
squarebrackets
  • 457
After more research, it seems that the -B and -S options of hdparm just doesn't work with certain Western Digital (and maybe other) drives.
This includes my WD10EADS, WD10EACS and WD20EARX.
I found a solution: hd-idle
To install hd-idle on Ubuntu:
wget https://downloads.sourceforge.net/project/hd-idle/hd-idle-1.04.tgz
tar xvfz hd-idle*.tgz
cd hd-idle
sudo apt-get install debhelper
sudo dpkg-buildpackage -uc -us -rfakeroot
cd ..
sudo dpkg -i hd-idle_*.deb
# To run at startup:
sudo update-rc.d hd-idle defaults
nano /etc/default/hd-idle
/etc/default/hd-idle content:
START_HD_IDLE=true
# Optional, to limit to a specific drives:
# (leading '-i 0' to disable hd-idle on other disks)
HD_IDLE_OPTS="-i 0 -a /dev/disk/by-uuid/DRIVE1UID -i 600 -a /dev/disk/by-uuid/DRIVE2UID -i 600"
Disable system-managed disk power management settings in Storage > Physical Disks > Disk properties (redundant).
sudo service hd-idle start
Check:
sudo hdparm -C /dev/sd[a-z]
KrisWebDev
  • 1,680
squarebrackets
  • 457
The ubuntu way seems to be the laptop mode*
How to:
apt-get install laptop-mode-tools
Afterwards you are able to configure individual power/standby settings through
vim /etc/hdparm.conf
And check your current laptop mode state with:
cat /proc/sys/vm/laptop_mode
If you want to know more:
Braiam
  • 69,112
