I just installed Ubuntu 16.04 LTS Server. And I want to disable hard drive when it is not used for a long time using SMART capabilities.
So, is it possible to prevent any Ubuntu writes on a hard drive in idle? And from what things should I start?
GLaz
  • 333
You can set a disk to spin down when it is not accessed for a certain period of time
You need to edit /etc/hdparm.conf
try an entry along the lines of
/dev/disk/by-id/disk_id { spindown_time = 36 }
The spindown time is in blocks of 5 seconds, so 36 means spindown after 3 minutes on inactivity. disk_id is the id of the disk you want to spin down (ls -l /dev/disk/by-id to find the right one)
Nick Sillito
  • 1,636
