if I run my notebook on battery mode, ubuntu spindown my hardrive every few seconds. How can I fix that? I have tried it with sudo hdparm -S 127 /dev/sda* but I am not able to disable the spindown and can“t find the reason for this "bug". Running Ubuntu 12.04 - Bug is since 12.04
Recent updates are installed, the problem is still recent. I can change the settings via. sudo hdparm -B 127 but if I change hdparm.conf, Ubuntu does not recognize it.
/dev/sda {
  apm_battery=127
fossfreedom
  • 174,526
norpol
I think this is the bug affecting you:
https://bugs.launchpad.net/ubuntu/+source/hdparm/+bug/952556
It's supposed to be solved in updates, so please check for updates and apply the latest ones (the one you want is hdparm (9.37-0ubuntu3.1) ). I suggest you reboot after applying them to be on the safe side.
If that doesn't help, the bug has some more suggestions to try. For instance, open a terminal and:
sudo gedit /etc/hdparm.conf
At the very end add this (on a new line):
apm_battery = 128
Then save the file.
You can try this manually by running
sudo hdparm -B 128 /dev/sda
but this will not persist once you've rebooted, so if it works for you, add it to the file as explained above.
roadmr
  • 34,802
The bug is/was caused the laptop_mode-tools. laptop_mode-tools ignores your /etc/hdparm.conf settings. To fix it, edit sudo gedit /etc/laptop-mode. Find this part:
# Power management for HD (hdparm -B values)
BATT_HD_POWERMGMT=1
And change it to:
 BATT_HD_POWERMGMT=127
To check if your new config is in use, disconnect from Power-Supply run:
sudo hdparm -I /dev/sda
Eliah Kagan
  • 119,640
nordpol
