166
I have a largish music collection and there are some duplicates in there. Is there any way to find duplicate files. At a minimum by doing a hash and seeing if two files have the same hash.
Bonus points for also finding files with the same name apart from the extension - I think I have some songs with both mp3 and ogg format versions.
I'm happy using the command line if that is the easiest way.
Hamish Downer
  • 19,506
12 Answers12
189
fdupes
I use fdupes for this. It is a commandline program which can be installed from the repositories with sudo apt install fdupes. You can call it like fdupes -r /dir/ect/ory and it will print out a list of dupes. fdupes has also a README on GitHub and a Wikipedia article, which lists some more programs.
Pablo Bianchi
  • 17,371
qbi
  • 19,515
71
List of programs/scripts/bash-solutions, that can find duplicates and run under nix:
  1. dupedit: Compares many files at once without checksumming. Avoids comparing files against themselves when multiple paths point to the same file.
  2. dupmerge: runs on various platforms (Win32/64 with Cygwin, *nix, Linux etc.)
  3. dupseek: Perl with algorithm optimized to reduce reads.
  4. fdf: Perl/c based and runs across most platforms (Win32, *nix and probably others). Uses MD5, SHA1 and other checksum algorithms
  5. freedups: shell script, that searches through the directories you specify. When it finds two identical files, it hard links them together. Now the two or more files still exist in their respective directories, but only one copy of the data is stored on disk; both directory entries point to the same data blocks.
  6. fslint: has command line interface and GUI.
  7. liten: Pure Python deduplication command line tool, and library, using md5 checksums and a novel byte comparison algorithm. (Linux, Mac OS X, *nix, Windows)
  8. liten2: A rewrite of the original Liten, still a command line tool but with a faster interactive mode using SHA-1 checksums (Linux, Mac OS X, *nix)
  9. rdfind: One of the few which rank duplicates based on the order of input parameters (directories to scan) in order not to delete in "original/well known" sources (if multiple directories are given). Uses MD5 or SHA1.
  10. rmlint: Fast finder with command line interface and many options to find other lint too (uses MD5), since 18.04 LTS has a rmlint-gui package with GUI (may be launched by rmlint --gui or from desktop launcher named Shredder Duplicate Finder)
  11. ua: Unix/Linux command line tool, designed to work with find (and the like).
  12. findrepe: free Java-based command-line tool designed for an efficient search of duplicate files, it can search within zips and jars.(GNU/Linux, Mac OS X, *nix, Windows)
  13. fdupe: a small script written in Perl. Doing its job fast and efficiently.1
  14. ssdeep: identify almost identical files using Context Triggered Piecewise Hashing
N0rbert
  • 103,263
v2r
  • 9,707
65
FSlint has a GUI and some other features. The explanation of the duplicate checking algorithm from their FAQ:
1. exclude files with unique lengths
2. handle files that are hardlinked to each other
3. exclude files with unique md5(first_4k(file))
4. exclude files with unique md5(whole file)
5. exclude files with unique sha1(whole file) (in case of md5 collisions).
fslint installation instructions
Dominik
  • 759
If your deduplication task is music related, first run the picard application to correctly identify and tag your music (so that you find duplicate .mp3/.ogg files even if their names are incorrect). Note that picard is also available as an Ubuntu package.
That done, based on the musicip_puid tag you can easily find all your duplicate songs.
Another script that does this job is rmdupe. From the author's page:
rmdupe uses standard linux commands to search within specified folders for duplicate files, regardless of filename or extension. Before duplicate candidates are removed they are compared byte-for-byte. rmdupe can also check duplicates against one or more reference folders, can trash files instead of removing them, allows for a custom removal command, and can limit its search to files of specified size. rmdupe includes a simulation mode which reports what will be done for a given command without actually removing any files.
girardengo
  • 5,005
jdupes
I found jdupes very easy and extremely fast.
jdupes is a program for identifying and taking actions upon duplicate files such as deleting, hard linking, symlinking, and block-level deduplication (also known as "dedupe" or "reflink"). It is faster than most other duplicate scanners. It prioritizes data safety over performance while also giving expert users access to advanced (and sometimes dangerous) features.
# Search a single directory:
jdupes path/to/directory
Search multiple directories:
jdupes directory1 directory2
Search all directories recursively:
jdupes --recurse path/to/directory
Search directory recursively and let user choose files to preserve:
jdupes --delete --recurse path/to/directory
Search multiple directories and follow subdirectores under directory2, not directory1:
jdupes directory1 --recurse: directory2
Search multiple directories and keep the directory order in result:
jdupes -O directory1 directory2 directory3
EXclude files over 1M, sumarize info, recursive
jdupes -X size+=:1000k --summarize --recurse ~
Pablo Bianchi
  • 17,371
I use komparator - sudo apt-get install komparator (Ubuntu 10.04+ ) - as GUI-tool for finding duplicates in manual mode.
N0rbert
  • 103,263
Have you tried
finddup
or
finddup -l
I guess it works fine.
blade19899
  • 26,994
xerostomus
  • 1,060
For Music related duplicate identification and deletion, Picard (open source) by http://musicbrainz.org/ and Jaikoz (privative) are the best solutions. Jaikoz I believe automatically tags your music based on the data of the song file. You don't even need the name of the song for it to identify the song and assign all metadata to it. Although the free version can tag only a limited number of songs in one run, but you can run it as many times as you want.
Pablo Bianchi
  • 17,371
Yathi
  • 199
dupeGuru has a dedicated mode for music. It is a cross-platform GUI program and, as of today (February 2021), it is in active development, although it is unclear which releases work on which systems. Check its documentation.
Diego V
  • 430
  • 14
Now that fslint is no longer supported, I've switched to fclones. As requested, it matches by hash, and can output a list, or replace files with hard or soft links.
I've been using it like this to replace duplicate files with hard links:
fclones group <dir/to/recursively/search> | fclones link
craq
  • 237
If you're fine with a GUI tool instead, I can highly recommend Czkawka. You can very easily find duplicate files, filter out the files you want (they are grouped by default) and delete the files you do not need. Also search is very fast and cached, so the next time you run it, it will be even faster.
demo video
https://github.com/qarmin/czkawka
You can easily install it on any distro, e.g. get it here on Flathub.
And if you insist on a CLI tool, the software itself also has/can be run as a CLI tool.
Also, it also seems to work on Windows or so.
(Reposted as from the similar question on SE Unix.)
rugk
  • 1,043
