When the only difference is the name booth files should have the same content and size.
1. About the content. We can compare two files by the command diff file-1 file-2. Also we can use this command for a test in this way:
diff -q file-1 file-2 > /dev/null && echo 'equal' || echo 'different'
2. About the size. We can find a file with certain size by the command (where 12672 is the file size in bytes):
find /path/to/search -type f -size 12672c -printf '%p\n'
Or we can use a range in this way (where 12600-12700 is the file size range in bytes):
find /path/to/search -type f -size -12700c -size +12600c -printf '%p\n'
Note that, by default the command find works recursively.
3. Combine the two methods (where file-1 is our pattern file):
find /path/to/search -type f -size -12700c -size +12600c -printf '%p\t' -exec sh -c 'diff -q file-1 "$1" > /dev/null && echo "equal" || echo "different"' sh {} \;
4. Example. Let's assume we have the following directory structure:
$ tree /tmp/test
/tmp/test
├── file-1 # this is the pattern file
├── file-2 # this is almost the same file but wit few additional characters
└── file-3 # this is exact copy of file-1
The result of the above command will be:
$ find /tmp/test -type f -size -12700c -size +12600c -printf '%p\t' -exec sh -c 'diff -q file-1 "$1" > /dev/null && echo "equal" || echo "different"' sh {} \;
/tmp/test/file-2 different # OK: here we have added few additional characters
/tmp/test/file-3 equal # OK: this is exact copy of file-1
/tmp/test/file-1 equal # OK: this is file-1 compared to its self
Or we can simplify the output by changing our command in this way:
$ find /tmp/test -type f -not -name "file-1" -size -12700c -size +12600c \
-exec sh -c 'diff -q file-1 "$1" > /dev/null && printf "%s\tis equal\n" "$1"' sh {} \;
/tmp/test/file-3 is equal
Update from the comments. The following command finding for file with the same size as the file-1, and then the diff commas is involved with --brief and --report-identical-files options:
find /path -type f -not -name "file-1" -size $(stat -c%s file-1)c -exec diff -qs file-1 {} \;
Files file-1 and /tmp/test/file-3 are identical
We can compare md5sum of the files in this way:
Get the md5sum of the pattern file:
$ md5sum file-1
d18b61a77779d69e095be5942f6be7a7 file-1
Use it with our command:
$ find /path -type f -not -name "file-1" -size $(stat -c%s file-1)c -exec sh -c 'echo "d18b61a77779d69e095be5942f6be7a7 $1" | md5sum -c -' sh {} \;
/tmp/test/file-3: OK
