321
When I'm doing something that requires root be typed in dozens of times in a row, I prefer to switch my session to a root session. In the various tutorials and instructions I have used on the Internet, I see sudo su, sudo su -, sudo -i and sudo /bin/bash being used to open a root session, but I'm not clear on the difference between these and when or if that difference matters.
Can someone clear this up for me?
chaos
  • 28,186
Paul
  • 4,606
To explain this you need to know what the programs do:
  • su - The command su is used to switch to another user (s witch u ser), but you can also switch to the root user by invoking the command with no parameter. su asks you for the password of the user to switch, after typing the password you switched to the user's environment.
  • sudo - sudo is meant to run a single command with root privileges. But unlike su it prompts you for the password of the current user. This user must be in the sudoers file (or a group that is in the sudoers file). By default, Ubuntu "remembers" your password for 15 minutes, so that you don't have to type your password every time.
  • bash - A text-interface to interact with the computer. It's important to understand the difference between login, non-login, interactive and non-interactive shells:
Types of shells:
  • login shell: A login shell logs you into the system as a specified user, necessary for this is a username and password. When you hit ctrl+alt+F1 to login into a virtual terminal you get after successful login a login shell.
  • non-login shell: A shell that is executed without logging in, necessary for this is a currently logged-in user. When you open a graphic terminal in gnome it is a non-login shell.
  • interactive shell: A shell (login or non-login) where you can interactively type or interrupt commands. For example a gnome terminal.
  • non-interactive shell: A (sub)shell that is probably run from an automated process. You will see neither input nor output.
So the cases are:
  • sudo su Calls sudo with the command su. Bash is called as interactive non-login shell. So bash only executes .bashrc. You can see that after switching to root you are still in the same directory:
    user@host:~$ sudo su
    root@host:/home/user#
  • sudo su - This time it is a login shell, so /etc/profile, .profile and .bashrc are executed and you will find yourself in root's home directory with root's environment.
  • sudo -i It is nearly the same as sudo su - The -i (simulate initial login) option runs the shell specified by the password database entry of the target user as a login shell. This means that login-specific resource files such as .profile, .bashrc or .login will be read and executed by the shell.
  • sudo /bin/bash This means that you call sudo with the command /bin/bash. /bin/bash is started as non-login shell so all the dot-files are not executed, but bash itself reads .bashrc of the calling user. Your environment stays the same. Your home will not be root's home. So you are root, but in the environment of the calling user.
  • sudo -s reads the $SHELL variable and executes the content. If $SHELL contains /bin/bash it invokes sudo /bin/bash (see above).
Check:
To check if you are in a login shell or not (works only in bash because shopt is a builtin command):
shopt -q login_shell && echo 'Login shell' || echo 'No login shell'
Pablo Bianchi
  • 17,371
chaos
  • 28,186
To look for differences you may chack the resulting environment among different invocations.
You could find some "small" differences in some critical variables:
  • PATH, LD_LIBRARY_PATH, LD_PRELOAD
or some difference in ~/. dotfiles handling (~/.config).
Consider also the ownership of $HOME based logfiles (~/.xsession.errors, etc ...) or xauth cookies (~/.Xauthority) that commands generate.
Try these commands:
# 'su -' vs 'su'
diff <(sudo su - -c env | sort) <(sudo su -c env | sort)
# 'su -' vs 'sudo -i'
diff <(sudo su - -c env | sort) <(sudo -i env | sort)
hute37
  • 171
