When I enter sudo su or sudo -i in terminal on Ubuntu 12.04, I cannot become superuser. When I enter the password nothing happens. Its like:
user@host~: sudo -i
enter passwd: ******
user@host~: nothing happened
And then:
user@host~: sudo -s
root@user~: WTF?
Instead when my normal user enters sudo -s it becomes root. Wtf...?
Lucio
  • 19,191
  • 32
  • 112
  • 191
It seems you wrong default shell setup for the root user.
  • In 1st command sudo -i, you passed the login authentication but no shell run.
  • In 2nd command sudo -s, you are already passed sudo authentication which it you are only asked onces per terminal (may be it has a timeout period). However this time, it loads directly /bin/bash not shell set in the root profile.
To test this theory run:
sudo -i /bin/bash
Related: 'sudo su -' vs 'sudo -i' vs 'sudo /bin/bash' - when does it matter which is used, or does it matter at all?
user.dz
  • 49,176
