-1
I added a user to the root group, but the user is still not able to perform operations that require root's permissions. What is the problem?
Zanna
  • 72,312
John Ronald
  • 2,526
Root login is disabled on Ubuntu. Adding user to root group will only affect permissions of files what have root group, for example edit some config files without sudo. Use sudo before a command to run that command as root, or sudo -i to get a root shell.
Zanna
  • 72,312
LeonidMew
  • 2,802
root login is disabled on Ubuntu. Adding user to the root group will only allow access to files that have root group, for example some config files. Being in the root group does NOT give any special privs.
To grant a user access to sudo, read man sudoers and add them to the sudo group.
adduser <username> sudo
The, once the other user logs out&in, or does a newgrp sudo, the other user will be able to preface his/her command with sudo to run as root, e.g. sudo wc -l /etc/shadow.
waltinator
  • 37,856
