Overcoming aptitude's Multiarch Bug for ppa-purge
Normally, as Vadim Rutkovsky and Takkat have explained, running ppa-purge with default syntax is an effective way to remove all packages provided by a PPA, properly downgrading them to versions provided in other configured software sources whenever possible.
However, as Takkat has pointed out, bug 831768 prevents ppa-purge from working properly to remove multiarch packages (like 32-bit packages installed on 64-bit systems). This is because aptitude cannot handle conflicting dependencies in multiarch packages (that's what the bug is about), and the default behavior of ppa-purge is to use aptitude to downgrade packages.
Fortunately, ppa-purge accepts the -i flag which causes it to prefer apt-get to aptitude as its backend. As documented in the bug report, using apt-get is an effective alternative to manually invoking aptitude, so running ppa-purge with the -i flag should be an effective workaround for removing/downgrading all packages provided by a PPA, including multiarch packages.
How To Do It
Here's the syntax:
sudo ppa-purge -i ppa:ppaowner/ppaname
As usual (same as when the -i flag is not used):
ppaowner is replaced with the owner of the PPA.
/ppaname is optional. If present, ppaname is replaced with the name of the PPA. If not, it defaults to ppa.
For example, suppose I had the PPA for unstable builds of qBittorrent installed, and I wanted to remove it completely, automatically downgrading qBittorrent to whatever version is available through my other software sources using apt-get behind the scenes instead of aptitude. Then I would run:
sudo ppa-purge -i ppa:hydr0g3n/qbittorrent-unstable
Where It's Documented
For some reason, a few useful options for ppa-purge are not documented in its manual page, including -i. But you can get information about them by running ppa-purge -h (or just ppa-purge with no arguments):
ek@Del:~$ ppa-purge -h
Usage: sudo ppa-purge [options] <ppa:ppaowner>[/ppaname]
ppa-purge will reset all packages from a PPA to the standard
versions released for your distribution.
Options:
-p [ppaname] PPA name to be disabled (default: ppa)
-s [host] Repository server (default: ppa.launchpad.net)
-d [distribution] Override the default distribution choice.
-y Pass -y --force-yes to apt-get or -y to aptitude
-i Reverse preference of apt-get upon aptitude.
-h Display this help text
Example usage commands:
sudo ppa-purge xorg-edgers
will remove https://launchpad.net/~xorg-edgers/+archive/ppa
sudo ppa-purge -p xorg-testing sarvatt
will remove https://launchpad.net/~sarvatt/+archive/xorg-testing
sudo ppa-purge ppa:ubuntu-x-swat/x-updates
will remove https://launchpad.net/~ubuntu-x-swat/+archive/x-updates
Notice: If ppa-purge fails for some reason and you wish to try again,
(For example: you left synaptic open while attempting to run it) simply
uncomment the PPA from your sources, run apt-get update and try again.
"Reverse preference of apt-get upon aptitude" is a bit cryptic. By looking at the relevant piece of the source code (ppa-purge is just a shell script, after all), we can see that this means that the default behavior is to prefer aptitude to apt-get, and the -i flag reverses this preference.
