Possible Duplicate:
How do I remove all packages from a certain repository?
i have installed programs from the nautilus-actions-extra and it cause a lot of problems so i want to remove this repository and all it's programs. so how to do that ???
Possible Duplicate:
You can try ppa-purge.
For that, you need to already have the PPA to your system so that ppa-purge can analyse the packages installed from that PPA.
First of all, install ppa-purge by running the following command in a terminal: sudo apt-get install ppa-purge
Then, run a command similar to this: sudo ppa-purge nautilus-actions-extra
After running ppa-purge, run sudo apt-get update && sudo apt-get upgrade and the packages will be reverted to the default repository.
Alternatively, in Synaptic (if you don't have Synaptic installed, run sudo apt-get install synaptic), you can filter available packages by origin, then click on the PPA containing the packages you wish to remove, then select them for removal or complete removal. Then in Software Sources you can remove the PPA and update package listings either by clicking on the "Reload" button in Synaptic or running sudo apt-get update in the terminal.
