I was just trying to install virtualbox using
apt-get install virtualbox
And show in my ubuntu:
 perl-base : Breaks: debconf (< 1.5.61) but 1.5.58ubuntu1 is to be installed
             Breaks: debconf:i386 (< 1.5.61)
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
why happen and how i can solve it??
sources.list:
# deb cdrom:[Ubuntu 16.04.3 LTS _Xenial Xerus_ - Release i386 (20170801)]/ xenial main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://in.archive.ubuntu.com/ubuntu/ xenial main restricted
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://in.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://in.archive.ubuntu.com/ubuntu/ xenial universe
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial universe
deb http://in.archive.ubuntu.com/ubuntu/ xenial-updates universe
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://in.archive.ubuntu.com/ubuntu/ xenial multiverse
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial multiverse
deb http://in.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://in.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu xenial partner
# deb-src http://archive.canonical.com/ubuntu xenial partner
deb http://security.ubuntu.com/ubuntu xenial-security main restricted
# deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
deb http://security.ubuntu.com/ubuntu xenial-security universe
# deb-src http://security.ubuntu.com/ubuntu xenial-security universe
deb http://security.ubuntu.com/ubuntu xenial-security multiverse
# deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
# Kali linux repositories | Added by Katoolin
deb http://http.kali.org/kali kali-rolling main contrib non-free**
vidarlo
  • 23,497
Mohamed El Alami
  • 45
You have Kali in your sources list. If we look up debconf for Xenial (16.04), the latest version is 1.5.58ubuntu1 at the time of this writing. You have a newer debconf, probably from kali.
Kali's Packages list indicates that the latest version of debconf in kali is 1.5.66.
You probably also have perl-base from kali repository. perl-base is listed as breaking debconf << 1.5.61.
The problem is that you have multiple repositories with mutually exclusive dependencies - which will create problems. Kalis repositories is supposed to provide the whole system, not only parts of it.
You may have a look at this answer which discusses how to remove all packages from a particular repository, so that you can remove all Kali packages from your system, which should enable you to install virtualbox.
vidarlo
  • 23,497
