Can this version of QT4 be successfully be installed on Lucid. So many things I try to install depend on this.
Error: Dependency is not satisfiable: libqtcore4 (>= 4:4.7.0~beta1)
Calibre PPA-Lucid is showing 4:4.7.0-0ubuntu4~ppa2, but notes:
PACKAGE BUILD FAILURES (STATUS): -Calibre: It's a problem with qt4, I think, I'm trying a build on my main PPA. Which, if successful, will be copied to this repo.
I've also seen backports available for kubuntu of beta1 and beta2 but I'm running xubuntu and I really don't understand backports anyway.
Change Log
Version: *DELETED*  2011-07-24 05:30:54 UTC
 No changelog for deleted or moved packages.
Version: 4:4.7.0~beta2-0ubuntu1~lucid1~ppa1     2010-07-11 12:26:25 UTC
 qt4-x11 (4:4.7.0~beta2-0ubuntu1~lucid1~ppa1) lucid; urgency=low
   * Lucid backport
Source diff to previous version
Version: 4:4.7.0~beta1+git20100522-0ubuntu1~lucid1~ppa1     2010-06-10 00:24:09 UTC
 qt4-x11 (4:4.7.0~beta1+git20100522-0ubuntu1~lucid1~ppa1) lucid; urgency=low
   * Lucid backport
Is this a lost cause?
akovia
  • 117
Backports are
https://help.ubuntu.com/community/UbuntuBackports
Kubuntu Backports
https://launchpad.net/~kubuntu-ppa/+archive/backports:
PPA description
Backports of new versions of KDE and major KDE apps for Kubuntu which are either too large a change or not yet tested enough to go to Ubuntu Backports.
There is available for the Lucid: qt4-x11 (4:4.7.0-0ubuntu2~lucid1~ppa2).
Upgrading from a PPA
You could go to the Kubuntu Backports and click the "Read about installing": https://launchpad.net/+help-soyuz/ppa-sources-list.html. Upgrade will only upgrade the installed packages (Qt).
Downgrade from the PPA
A package:
:~$ apt-cache show ppa-purge
Description: disables a PPA and reverts to official packages
This program disables a PPA from your Software Sources and reverts your system back to the official Ubuntu packages. You can use this to return your system to normal after testing a new version from a PPA.
Homepage: https://launchpad.net/ppa-purge
It is available from the lucid-backports: http://packages.ubuntu.com/search?keywords=ppa-purge&searchon=names&suite=all&section=all
More:
user26687
  • 15,174
