12
I know waking from suspend is an issue, but this looks like a separate bug.
When I suspend 13.10 on HP Pavillion dv6 (AMD 6770M/fglrx 13.10.10) from x, it suspends normally but freezes when waking. I get a black screen with a frozen cursor.
But when I suspend from console with sudo pm-suspend, it wakes normally, and I can then get back my x with Ctrl+Alt+F7.
If I suspend by closing lid under x, also freezes when waking up. If I suspend by closing lid under console, it wakes up into the x (?) login, then into a clean session.
UPDATE. I checked my syslog, kern.log and pm-suspend.log, they appear to show a standard suspend procedure which is completed normally, then followed by many blank lines (000s), then normal start procedure after hard reset. I may be wrong but looks like kernel panic to me.
Also, if I suspend with dbus (How can I suspend/hibernate from command line?) instead of pm-suspend, outcome is same.
Pavel
  • 1,556
Seems I have same issue and with help of your testing I found workaround. Make a script that switch to console before suspend and switch back after resume.
In a terminal run sudoedit /etc/pm/sleep.d/fglrx-fix and paste in the following script. Afterwards make it executable by running sudo chmod u+x /etc/pm/sleep.d/fglrx-fix
Script:
#!/bin/bash
#Script kills autofs when going into standby to eliminate issues with it
case $1 in
suspend)
#suspending to RAM
    chvt 1
    echo "Going to sleep"
    sleep 1
resume)
#resume from suspend
    echo "try to resume"
    sleep 1
    chvt 7
esac
Oli
  • 299,380
Jan Brezina
  • 196
Jan's answer worked perfect for me, but the issue would still happen on hibernate. To fix this, I modified a tiny bit of the script:
#!/bin/bash
case $1 in
suspend|hibernate)  # instead of just "suspend"
#suspending to RAM
    chvt 1
    sleep 1
resume|thaw)  # instead of just "resume"
    sleep 1
    chvt 7
esac
ido
  • 139
