I am new to ubuntu and I am trying to create a file to fix a suspend problem I have with my system. I have found the answer here as follows:
Put attached script into dir /etc/pm/sleep.d e.g. with name fglrx-fix and make it executable (chmod u+x /etc/pm/sleep.d/fglrx-fix)
#!/bin/bash
#Script kills autofs when going into standby to eliminate issues with it
case $1 in
suspend)
#suspending to RAM
    chvt 1
    echo "Going to sleep"
    sleep 1
resume)
#resume from suspend
    echo "try to resume"
    sleep 1
    chvt 7
esac
I just cannot work out how to create the file in terminal, if someone could give a me a step by step instruction that would be great!
albany
  • 73
You'd most commonly use a command line editor like nano. You need to run it as root because of where you're trying to write:
sudo nano /etc/pm/sleep.d/fglrx-fix
nano will open up allowing you to paste the code in. Control+X to exit (press Y to confirm that you want to save it and Return to confirm the filename).
Then (per the original instuctions) make it executable with:
sudo chmod +x /etc/pm/sleep.d/fglrx-fix
Oli
  • 299,380
