I have freshly installed and updated 13.10 I suspended it for first time yesterday and today it wouldn't start up but just show a blank black page. The monitor goes in power save mode after a while. So nothing happens.
the PC has 12GB ram and 13000 mbytes of swap partition if that matters.
I am/was having the same issue. Computer has blank screen after resume. It appears that the backlight is just not illuminating because I feel like I can see everything just without light.
HP Compaq Presario F763NR attempting to run with Ubuntu 13.10
I found, however, that I could 'wake' the system by Ctrl-Alt-F5, then Ctrl-Alt-F7.
First, before this - in order to prevent the computer from crashing when accessing Search your Computer and Resources - I was required to install the System Settings > Software & Updates > Additional Drivers > Using NVIDIA binary Xorg driver, kernel module and VDPAU library from nvidia-304-updates (proprietary).
Solution: create the file /etc/pm/sleep.d/99_wake_hack to contain:
#!/bin/sh
# Action script to activate the screen on resume.
# Without this script, the screen remains blank.
PATH=/sbin:/usr/sbin:/bin:/usr/bin
case "${1}" in
    hibernate|suspend)
            #nothing
    resume|thaw)
            chvt 5 && sleep 1 && chvt 7 &
esac
Essentially, I am switching the foreground virtual terminals. There is a command for this: chvt 5 && chvt 7. I require the sleep 1 and need execute in parallel (&) because the fix does not work if the chvt 7 happens before the wake_hack script (and other resume scripts) are complete.
I look forward to hearing better solutions to this problem.
-1
I pressed Fn+F3 (on my laptop: HP Pavilion dv6 3052) for increasing brightness of display and my problem was solved.
