14.04 and beyond
Mitch points out in his answer for 14.04 and 16.04 that you should check 10-vendor.d/com.ubuntu.desktop.pkla before modifying anything. Also check that you have Secure Boot disabled and if that brings the menu option back.
Re-enabling the hibernation option in the menu
To re-enable the hibernation option in the menu, your /etc/polkit-1/localauthority/50-local.d/com.ubuntu.enable-hibernate.pkla should be modified to look like the following in saucy (13.10):
[Re-enable hibernate by default in upower]
Identity=unix-user:*
Action=org.freedesktop.upower.hibernate
ResultActive=yes
[Re-enable hibernate by default in logind]
Action=org.freedesktop.login1.hibernate
ResultActive=yes
Then reboot or run killall indicator-session-service in your session and you should have your hibernate functionality/menu option back. Create the file if it doesn't exist already.
Investigation from bug report
Citation from Jeffery To's post on Launchpad Bug Report #1232814:
For Saucy, indicator-session was updated to use logind
(org.freedesktop.login1) instead of upower.
If you check
/var/lib/polkit-1/localauthority/10-vendor.d/com.ubuntu.desktop.pkla,
you'll see that hibernate is disabled by default in both upower and
logind.
So the first step to re-enable the Hibernate option is to edit
to something like:
ResultActive=yes
ResultActive=yes
After rebooting, the login screen session menu should have a Hibernate
option.
All thanks and credit go to Jeffery!
Why was hibernation disabled?
There exists a bug report on launchpad that suggests disabling suspend/hibernate instead of tracking which hardware "certifies" for which power modes. It's claimed to be a more scalable approach.
Another thing to mention is that using UEFI Secure Boot and hibernation appears to be possible but may be a risk to circumvent the former. (1, 2) As a reminder, when you use hibernation you store everything in RAM to disk without encryption, this includes passwords for encrypted filesystems and containers.
At some point with 16.04 I had to disable Secure Boot to be able to hibernate my laptops. In my case I used uswsusp and testing with s2disk returned the message below. This may give you a hint that your issue, why you can't hibernate although everything else is in place, is related to Secure Boot:
s2disk: Could not open the snapshot device. Reason: Operation not permitted
However, please understand that this is not a place to complain and please be nice.
Related questions
