10
I have lost the to me essential hibernate functionality after upgrading ubuntu. This is normal, but unfortunately I could not reenable it this time.
I tried these three previous solutions:
but no hibernation option appears.
Some additional info:
  • sudo pm-hibernate outputs nothing and appears to do nothing.
  • sudo s2disk outputs:
    s2disk: Could not open the snapshot device. Reason: Operation not permitted
I guess this is my key clue, but I didn't find any obvious explanations/solutions when googling that - I'm afraid I'm ignorant of the meaning.
There is no change to dmesg output and /var/log/pm-suspend.log does not exist after running pm-hibernate.
The machine is capable of hibernating under ubuntu 15.04 and earlier - the above options worked previously.
(I am aware this is a potential duplicate of this question, but wanted to add more detail.)
nsandersen
  • 273
  • 14
You need to disable Secure Boot if you are using UEFI.
With Secure Boot enabled hibernation is disabled for security reasons.
Pilot6
  • 92,041
In terminal, try sudo systemctl hibernate. If the system is able to do so, i.e. has enough swap space, it should work. Use of this command requires a password, which is not necessarily a bad thing, because it makes one pause to consider that the current system state is being recorded to a possibly-unencrypted HDD.
To make a Hibernate keyboard shortcut:
  • Press System and type key.
  • Select Keyboard settings.
  • on the Shortcuts tab, add to Custom Shortcuts the command systemctl hibernate and set a key combination. Note that sudo is not used here, though a password is requested when using the shortcut.
