I know there are lots of threads about this already, but none of them works for me. I tried the solution mentioned here:
- How to enable hibernation in 16.04
- Xubuntu 14.04: how to enable hibernate?
- How to enable hibernation?
- Hibernation is still missing from menu in 13.10 after enabling via polkit. How to enable?
- How can I hibernate on Ubuntu 16.04?
This is what I tried:
1) sudo pm-hibernate
doesn't do anything.
2) sudo gedit /etc/polkit-1/localauthority/50-local.d/com.ubuntu.enable-hibernate.pkla
That file now looks like this:
[Re-enable hibernate by default in upower] Identity=unix-user:* Action=org.freedesktop.upower.hibernate ResultActive=yes
[Re-enable hibernate by default in logind] Identity=unix-user:* Action=org.freedesktop.login1.hibernate;org.freedesktop.login1.handle-hibernate-key;org.freedesktop.login1;org.freedesktop.login1.hibernate-multiple-sessions;org.freedesktop.login1.hibernate-ignore-inhibit ResultActive=yes
[Re-enable hibernate by default for login1] Identity=unix-user:*
Action=org.freedesktop.login1.hibernate ResultActive=yes[Re-enable hibernate for multiple users by default in logind]
Action=org.freedesktop.login1.hibernate-multiple-sessions
ResultActive=yes
I also changed the file to this:
[Re-enable hibernate by default in logind] Identity=unix-user:* Action=org.freedesktop.login1.hibernate;org.freedesktop.login1.hibernate-multiple-sessions ResultActive=yes
... but still, it doesn't work.
3) sudo update-grub still no hibernate option in the menu
4) Installed tuxonice
sudo add-apt-repository ppa:tuxonice/ppa
sudo apt-get update
sudo apt-get install tuxonice-userui linux-generic-tuxonice linux-headers-generic-tuxonice
Then sudo pm-hibernate. No results
5) sudo apt-get install hibernate then sudo systemctl hibernate I get this error message:
Failed to hibernate system via logind: Sleep verb not supported
6) sudo gedit /var/lib/polkit-1/localauthority/10-vendor.d/com.ubuntu.desktop.pkla then looked for
[Disable hibernate by default in upower]
[Disable hibernate by default in logind]
...and changed ResultActive=no to ResultActive=yes
Additional information:
- After executing the steps above and restarting my PC for every steps I mentioned above, hibernate still doesn't show up.
- Ubuntu 16.04; IntelĀ® Kabylake GT2
- I'm using an SSD
- My swap is larger than my mem (tested with
free). sudo locate pm-suspend.logdoesn't result in anything after executingsudo pm-hibernate- I executed
dmesgbefore and after executingsudo pm-hibernateand compared the two outputs ofdmesg. Both outputs are identical
EDIT:
I think I found the reason: You have to disable the secure boot option in the BIOS. To do that, interrupt the normal boot process and it is in the option secure boot.
