For Kingston drives on Debian-based computers
Similar to this answer execute
# apt-get install smartmontools
However when I execute the command to show the drive info, it looks like SMART was disabled:
# smartctl -a /dev/sda
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-3.13.0-45-generic] (local build)
SMART support is: Available - device has SMART capability.
SMART support is: Disabled
You need to enable that by executing the following as root:
# smartctl -s on -a /dev/sda
You can then execute a self-test by doing either a short test (which took me about 1 minute):
# smartctl -t short -a /dev/sda
or a more thorough test (which took me about 1.5 hours):
# smartctl -t long -a /dev/sda
Note, in most circumstances you do not need to unmount the drive to execute these tests. If you do, see man smartctl.
Now, when you execute smartctl -a /dev/sda you should then see a self-assessment test result. This is probably all you really need to concern yourself with:
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
If you like details, you will also see a table like this:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x0032 095 095 050 Old_age Always - 0/178007034
5 Retired_Block_Count 0x0033 100 100 003 Pre-fail Always - 0
9 Power_On_Hours_and_Msec 0x0032 092 092 000 Old_age Always - 7626h+46m+45.580s
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 8
171 Program_Fail_Count 0x000a 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
174 Unexpect_Power_Loss_Ct 0x0030 000 000 000 Old_age Offline - 4
177 Wear_Range_Delta 0x0000 000 000 000 Old_age Offline - 1
181 Program_Fail_Count 0x000a 100 100 000 Old_age Always - 0
182 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0012 100 100 000 Old_age Always - 0
189 Airflow_Temperature_Cel 0x0000 030 035 000 Old_age Offline - 30 (Min/Max 24/35)
194 Temperature_Celsius 0x0022 030 035 000 Old_age Always - 30 (Min/Max 24/35)
195 ECC_Uncorr_Error_Count 0x001c 120 120 000 Old_age Offline - 0/178007034
196 Reallocated_Event_Count 0x0033 100 100 003 Pre-fail Always - 0
201 Unc_Soft_Read_Err_Rate 0x001c 120 120 000 Old_age Offline - 0/178007034
204 Soft_ECC_Correct_Rate 0x001c 120 120 000 Old_age Offline - 0/178007034
230 Life_Curve_Status 0x0013 100 100 000 Pre-fail Always - 100
231 SSD_Life_Left 0x0013 100 100 010 Pre-fail Always - 0
233 SandForce_Internal 0x0032 000 000 000 Old_age Always - 3498
234 SandForce_Internal 0x0032 000 000 000 Old_age Always - 2885
241 Lifetime_Writes_GiB 0x0032 000 000 000 Old_age Always - 2885
242 Lifetime_Reads_GiB 0x0032 000 000 000 Old_age Always - 868
If you are looking for what all of these values mean, see the Kingston documentation.
