I'm just newbie with Ubuntu/Linux. Actually I am attempting to install Pyrit which requires GPU acceleration.
I have dual-booted Ubuntu 13.04 and Windows 7 in my Desktop PC Gigabyte G31M-ES2C with:
  • Processor: Intel Core 2 Duo
  • RAM: 4.00 GB
  • Graphics:
    • Integrated Intel Graphics
    • Nvidia GT 520 (I think with Optimus)
I have tried many times to install CUDA but unsuccessfully. Can someone explain to me how to install it with details?
I've heard about Bumblebee, which might help me with an Optimus card. How can I make use of it? I've heard I have to uninstall Nouveau first.
When I tried with Bumblebee everything seemed perfect except the following error appears:
optirun glxgears -info
  ERROR-Bumblebee daemon has not been started yet or the socket path /var/<...>
  ERROR-Could not connect to bumblebee daemon - is it running?
I need a way to install Pyrit or just CUDA, any help is appreciated.
edwin
  • 3,829
This description is working with hybrid-cards of nvidia, who contains CUDA chipset (additionally in some cases with 'Optimus'-feature) like those with letter 'M' as graphics-cards for notebooks.
no question - linux-headers have to be installed first suiting to your installed kernel.
in case of hybrid-chipsets like CUDA with Optimus this following package might NOT work entirely :
NVIDIA-Linux-x86_64-310.51.run
you instead should try this package:
NVIDIA_CUDA_SDK_1.1_Beta_Linux.run
You can download it here:
http://www.nvidia.de/object/cuda_1_1_beta.html
In this example the 1 year old graphics hypbrid chipset with GeForce 540M CUDA Optimus (notebooks) - CUDA_SDK_1.1_Beta is working quite good ...
On desktop in terminal one first needs to do:
export PATH=${PATH}:/usr/local/cuda/bin
and on 32-bit-machines this:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/nvidia-current:/usr/lib32/nvidia- current
but on 64-bit-machines this:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib:/usr/local/cuda/lib64
I have kernel 3.9.0 and after:
Strg-Alt-F1 (use Ctrl instead of Strg on most non-German keyboards)
apt-get update
then it depends on your system what works better:
either this package for 32-bit:
apt-get install nvidia-current
or either this package for 64-bit:
apt-get install nvidia-current-updates
(never mix these both packages !)
I simply went out of x:0 with looking for x-window processes (gdm, lightdm, xdm, kdm and else ... ) with top and then ended all concerning x:0-processes with killing them manually:
(in protected mode resp. Strg-Alt-F1)
kill -9 PID number-of-PID
( this works more explicitly than xdm stop, gdm stop or kdm stop resp. lightdm stop and commands like init or telinit are not to recommend here in 12.10 - I write this here, because in many tutorials regarding nvidia these stopping commands are always told )
Then finally I simply ran off that package:
./NVIDIA_CUDA_SDK_1.1_Beta_Linux.run
when finish do not forget then:
 gdm start
 kdm start
 lightdm start
following is necessary in case of geforce-cards with cuda-optimus:
back to desktop with:
Strg-Alt-F7
there type into terminal
sudo add-apt repository ppa:bumblebee/stable
sudo apt-get update
sudo apt-get install --reinstall bumblebee virtualgl linux-headers-generic
(otherwise installation of cuda-sdk-package has no effect)
sudo reboot
now you should have wobbly graphics best working with compiz and cairo-dock and icon-fusion !!!
(remark: later after installing kernel 3.10 - Nvidia-driver CUDA-SDK-1.1 was accepted by 3.10 without further problems)
dschinn1001
  • 3,863
I've found this relatively simple approach for installing CUDA in Ubuntu. Unfortunately, the page seems to be incomplete and outdated (12.04).
https://help.ubuntu.com/community/Cuda
It basically involves the following steps:
Install the required packages:
sudo apt-get install libxi-dev libxmu-dev freeglut3-dev build-essential binutils-gold
Download "CUDA Toolkit" and "GPU Computing SDK". Substitute "32" for "64" if you're on 32 bits:
cd ~/Desktop
wget http://developer.download.nvidia.com/compute/cuda/4_2/rel/toolkit/cudatoolkit_4.2.9_linux_64_ubuntu11.04.run
wget http://developer.download.nvidia.com/compute/cuda/4_2/rel/sdk/gpucomputingsdk_4.2.9_linux.run
Install the CUDA toolkit (when prompted, choose /opt as the install path)
cd ~/Desktop
chmod +x cudatoolkit_4.2.9_linux_*
sudo ./cudatoolkit_4.2.9_linux_*
Install GPU Computing SDK (once again, choosing /opt as your install path upon prompt)
cd ~/Desktop
chmod +x gpucomputingsdk_4.2.9_linux.run
./gpucomputingsdk_4.2.9_linux.run
Prepare for compilation
export PATH=$PATH:/opt/cuda/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/cuda/lib:/opt/cuda/lib64
echo 'export PATH=$PATH:/opt/cuda/bin' >> ~/.bash_profile
echo 'export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/cuda/lib:/opt/cuda/lib64' >> ~/.bash_profile
Compile SDK
cd ~/NVIDIA_GPU_Computing_SDK/C
LINKFLAGS=-L/usr/lib/nvidia-current/ make cuda-install=/opt/cuda
NOTE: In case you are using the latest (post-release updates; version current-updates) instead of the recommended (version current) Nvidia drivers, then change the LINKFLAGS to read:
LINKFLAGS=-L/usr/lib/nvidia-current-updates/ make cuda-install=/opt/cuda
Test
~/NVIDIA_GPU_Computing_SDK/C/bin/linux/release/./fluidsGL
If you can see the picture, it works!
If you are using optimus with bumblebee, run the above with optirun as below:
optirun ~/NVIDIA_GPU_Computing_SDK/C/bin/linux/release/./fluidsGL
Cleanup
cd ~/Desktop
rm cudatoolkit_4.2.9_linux_*
rm gpucomputingsdk_4.2.9_linux.run
Uninstallation
rm -r ~/NVIDIA_GPU_Computing_SDK
sudo rm -r /opt/cuda
Also, remove the export PATH=$PATH:/opt/cuda/bin and export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/cuda/lib:/opt/cuda/lib64 lines of the ~/.bash_profile file.
Also, I've found this easy script
http://ammar.gr/?p=701
Which namely only works for 12.04, but according to Jiří Doubravský, it also works on 12.10 and 13.04.
