I have Kubuntu 13.04 installed on an HP envy DV7 with the dual graphics chipsets intel 4000 and Nvidia 630M. And when I try to reduce my screen brightness it doesn´t actually go down until it reaches 10%. I´m running the standard nouveau drivers, no proprietary drivers.
Braiam
  • 69,112
Try it once.. It has solved all problems about brightness! Including mine!!
  • Open terminal ( Ctrl+Alt+T ) and type:
    sudo cp /etc/default/grub /etc/default/grub.bak
    sudo gedit /etc/default/grub
    You will find this line in the new opened window: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
  • Change it to:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
  • Save and close the window and type this in the terminal:
    sudo update-grub
  • Restart your system..
Saurav Kumar
  • 15,174
