37
The default setting for synaptics touchpads includes a paste functionality mapped to the upper right corner of the touchpad. I can disable this behavior by running the command
synclient RTCornerButton=0
But every time I reboot my settings are reverted. How do I prevent this from happening?
muru
  • 207,228
cmatofte
  • 371
12 Answers12
21
You need to put the settings in a xorg.conf file as follows:
sudo gedit /usr/share/X11/xorg.conf.d/60-synaptics-options.conf
In the new file, type
Section "InputClass"
  Identifier "touchpad catchall"
  Driver "synaptics"
  MatchIsTouchpad "on"
  MatchDevicePath "/dev/input/event*"
  Option "RTCornerButton" "0"
EndSection
monkbroc
  • 361
13
Gnome settings daemon may override existing settings (for example ones set in xorg.conf.d) for which, the existing settings in /usr/share/X11/xorg.conf.d/50-synaptics.conf are being ignored. This is how i fixed it.
Run dconf-editor
Edit /org/gnome/settings-daemon/plugins/mouse/ (or /org/cinnamon/settings-daemon/plugins/mouse/ for cinnamon)
Uncheck the active setting
It will now respect your system's existing synaptics configuration.
Then follow monkbroc's solution which will work now.
ugly_duck
  • 161
(Maybe) the fastest workaround is to create an entry in the "Startup Applications". It could be found in the unity launcher.
An example entry looks something like this:
Name: Enable Palm Detection
Command: synclient PalmDetect=1
Comment: Enable synclient palm detection
This is essentially equivalent to Augustin Riedinger's answer, but instead of creating the desktop entry manually, we let Ubuntu to do it for us.
The best method that have worked for me is to add your changes into Xsession.d, so it will load automatically for all users when you log into X:
(the file doesn't exists, so you can name it whatever you want. The numbers on the left means the order in which it will be executed in comparison with the other files.)
/etc/X11/Xsession.d/80synaptics
(owned by root, with permissions 644)
For example, you can use this as base:
#https://wiki.archlinux.org/index.php/Touchpad_Synaptics
#Palm dimension
#synclient PalmDetect=1
#synclient PalmMinWidth=4
#synclient PalmMinZ=100
#Touchpad sensibility (move)
#synclient FingerLow=10
#synclient FingerHigh=20
#Click detection
#synclient MaxTapTime=180
#synclient MaxTapMove = 242
#synclient MaxDoubleTapTime = 180
#2 finger = right click
#synclient TapButton2=0
#3 finger = middle click
#synclient TapButton3=2
#click corners
#synclient RBCornerButton=0 MaxTapTime
#synclient RTCornerButton=0
#synclient LTCornerButton=0
#synclient LBCornerButton=0
#Oval instead of rectangular
#synclient CircularPad=1
#TapAndDragGesture
#synclient TapAndDragGesture=1
#scroll in sides
#synclient VertEdgeScroll=0
#synclient HorizEdgeScroll=0
#synclient CornerCoasting=0
#2 finger scroll
#synclient VertTwoFingerScroll=1
#synclient HorizTwoFingerScroll=0
#Disable Touchpad on start
#synclient TouchpadOff=1
Tested in Ubuntu 14.04 and 16.04
lepe
  • 1,506
Make synclient options stick between X sessions
Using startx (xinit)
Add any synclient <option>=<value> & lines to .xinitrc before the line which runs your window manager or desktop environment, like so:
## ~/.xinitrc
## X11 startup script; sourced by xinit(1) and its frontend startx(1)
Set Synaptics touchpad options
synclient RTCornerButton=0 &
Start desktop environment or window manager of your choice
exec startxfce4
exec startlxde
exec startkde
exec i3
exec dwm
The above example sets synclient options before running the Xfce desktop environment. Lines beginning with # are comments (they will not be executed).
Using a display manager
The method is the same as for xinit, except you put the synclient lines in a relevant startup script for your display manager, e.g. /etc/GDM/Init/Default.
If you have any doubts, let me refer you to the excellent ArchWiki. Even though its Archlinux-specific, most solutions work in every linux distro due to Arch's DIY nature. Have a good one!
rld.
  • 131
I'm using Xubuntu 14.04 and this may not work for you. Open Session and startup or whatever the name is for you. Go to Application Autostart tab, again whatever the name is for you. Click the add button. Keep whatever name and description you want to and in the command type:
If you want to add multiple lines separate them with a ;
Make sure the command you just created is checked.
Add synclient [Var=Value] to the end of ~/.bashrc
example: synclient RTCornerButton=0
This will make you system set this synclient setting every time you log in.
lindhe
  • 711
try touchegg, this solution worked on my XPS13 Ubuntu16.04 https://samtinkers.wordpress.com/2016/06/13/3-finger-gestures-in-ubuntu-16-04/
Amos Folarin
  • 1,214
All the solutions suggested here don't work for me:
  • I want the config to be in the /home folder as it is local config (so I can keep the parameters even if I change my distrib for instance)
  • .bashrc or .xinitrc don't seem to be executed correctly
So I ended up creating a .desktop file that is autostarted:
cat ~/.config/autostart/touchpadconfig.desktop
[Desktop Entry]
Name=Touchpad Config
GenericName=Touchpad Config
Comment=Sets better default parameters to touchpad
Exec="synclient VertScrollDelta=40 && synclient AccelFactor=0.1 && synclient RightButtonAreaTop && synclient RightButtonAreaLeft=0"
Terminal=false
Type=Application
Icon=input-mouse
Categories=Settings;
StartupNotify=false
Maybe not the best solution but it works for me.
None of the solutions worked for me in Ubuntu 14.04 LTS with Unity desktop. To make the settings permanent, I had to paste the synclient commands to a shell script and add the shell script to my Startup Applications in Unity.
Note: The shell script must start something like #!/bin/bash before the synclient commands, and the permissions have to be changed to executable.
kernpanik
  • 71
With Wayland (still experimental in 17.04, but soon to be the default), you have all the setting you need:
sudoedit /usr/share/X11/xorg.conf.d/50-synaptics.conf
add those lines in the Section "InputClass"
If you're using GNOME or Cinnamon desktop manager, there is a good chance that GNOME/Cinnamon's settings can override your custom settings. To prevent GNOME/Cinnamon's settings override yours, open dconf Editor [dconf-editor] and edit following entry:
or
Uncheck active.
Elin Y.
  • 889
  • 23
