Since I'm using 16.04, I have to manually start the rc.local service, so that commands in /etc/rc.local can be executed on start up. However, I'm having some trouble starting the service:
sunqingyao@sunqingyao-MacBookAir:~$ sudo service rc.local start
Job for rc-local.service failed because the control process exited with error code. See "systemctl status rc-local.service" and "journalctl -xe" for details.
Here is the output of systemctl status rc-local.service:
sunqingyao@sunqingyao-MacBookAir:~$ systemctl status rc-local.service
● rc-local.service - /etc/rc.local Compatibility
Loaded: loaded (/lib/systemd/system/rc-local.service; static; vendor preset: enabled)
Drop-In: /lib/systemd/system/rc-local.service.d
└─debian.conf
Active: failed (Result: exit-code) since Fri 2017-07-14 23:52:04 CST; 2min 13s ago
Process: 2420 ExecStart=/etc/rc.local start (code=exited, status=1/FAILURE)
Jul 14 23:52:04 sunqingyao-MacBookAir systemd[1]: Starting /etc/rc.local Compatibility...
Jul 14 23:52:04 sunqingyao-MacBookAir rc.local[2420]: Failed to connect to X Server.
Jul 14 23:52:04 sunqingyao-MacBookAir systemd[1]: rc-local.service: Control process exited, code=exited status=1
Jul 14 23:52:04 sunqingyao-MacBookAir systemd[1]: Failed to start /etc/rc.local Compatibility.
Jul 14 23:52:04 sunqingyao-MacBookAir systemd[1]: rc-local.service: Unit entered failed state.
Jul 14 23:52:04 sunqingyao-MacBookAir systemd[1]: rc-local.service: Failed with result 'exit-code'.
and for journalctl -xe:
Jul 14 23:52:04 sunqingyao-MacBookAir sudo[2390]: sunqingyao : TTY=pts/0 ; PWD=/home/sunqingyao ; USER=root ; COMMAND=/usr/sbin/service rc.local start
Jul 14 23:52:04 sunqingyao-MacBookAir sudo[2390]: pam_unix(sudo:session): session opened for user root by (uid=0)
-- Subject: Unit rc-local.service has begun start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit rc-local.service has begun starting up.
-- Subject: Unit rc-local.service has failed
-- Unit rc-local.service has failed.
-- The result is failed.
Jul 14 23:52:04 sunqingyao-MacBookAir sudo[2390]: pam_unix(sudo:session): session closed for user root
