I'm struggling to make my custom touchpad persistent.
I very well know the config I want. Here's the command, using synclient:
synclient RightButtonAreaLeft=0 RightButtonAreaTop=0 ClickTime=20 AccelFactor=0.3 MaxSpeed=2.5 PalmDetect=1 VertTwoFingerScroll=1 HorizTwoFingerScroll=1 VertEdgeScroll=0 HorizEdgeScroll=0
As explained here and there I created /etc/X11/xorg.conf.d/50-synaptics.conf instead of editing /usr/share/X11/xorg.conf.d/50-synaptics.conf with the following content:
Section "InputClass"
  Identifier "touchpad catchall"
  Driver "synaptics"
  MatchIsTouchpad "on"
  MatchDevicePath "/dev/input/event*"
  Option "RightButtonAreaLeft" "0"
  Option "RightButtonAreaTop" "0"
  Option "ClickTime" "20"
  Option "AccelFactor" "0.3"
  Option "MaxSpeed" "2.5"
  Option "PalmDetect" "1"
  Option "VertTwoFingerScroll" "1"
  Option "HorizTwoFingerScroll" "1"
  Option "VertEdgeScroll" "0"
  Option "HorizEdgeScroll" "0"
EndSection
Surprisingly, it does change something, as my mouse goes faster, but doesn't apply all options, as HorizTwoFingerScroll isn't available.
Since /usr/share/X11/xorg.conf.d/50-synaptics.conf is still there, I'm wondering if it isn't interfering. Here's what's in there:
# Example xorg.conf.d snippet that assigns the touchpad driver
# to all touchpads. See xorg.conf.d(5) for more information on
# InputClass.
# DO NOT EDIT THIS FILE, your distribution will likely overwrite
# it when updating. Copy (and rename) this file into
# /etc/X11/xorg.conf.d first.
# Additional options may be added in the form of
#   Option "OptionName" "value"
        Driver "synaptics"
# This option is recommend on all Linux systems using evdev, but cannot be
# enabled by default. See the following link for details:
# http://who-t.blogspot.com/2010/11/how-to-ignore-configuration-errors.html
#       MatchDevicePath "/dev/input/event*"
EndSection
        Identifier "touchpad ignore duplicates"
        MatchOS "Linux"
        MatchDevicePath "/dev/input/mouse*"
        Option "Ignore" "on"
EndSection
# This option enables the bottom right corner to be a right button on clickpads
# and the right and middle top areas to be right / middle buttons on clickpads
# with a top button area.
# This option is only interpreted by clickpads.
        Identifier "Default clickpad buttons"
        MatchDriver "synaptics"
        Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
        Option "SecondarySoftButtonAreas" "58% 0 0 15% 42% 58% 0 15%"
EndSection
# This option disables software buttons on Apple touchpads.
        Identifier "Disable clickpad buttons on Apple touchpads"
        MatchProduct "Apple|bcm5974"
        Option "SoftButtonAreas" "0 0 0 0 0 0 0 0"
EndSection
Why are there several ones? How can I disable them (considering I'm not allowed to edit the file)? Did I miss something?
I tried all from above, /etc/X11/xorg.conf.d/60-synaptics.conf, just /etc/X11/xorg.conf, startup-command in either xfce or mate and even startup-script with 10 seconds delay and then execute synclient-commands in a loop or without a loop. Nothing worked. Only thing I couldn't try was to set it via gsettings because I didn't find any touchpad settings there.
Working Solution for me was: Just adding the synclient command at the end of ~/.bashrc So in your case, just add:
Probably, adding it to ~/.xinit will do the same :) (adding it to .bashrc won't make an effect before you either re-login or execute source ~/.bashrc)
I know, bashrc is not the place where synclient settings should be stored, but after spending hours on this issue it is the only working solution for me and I'm not having any side effects.
update: I found this'll make "Mouse & Touchpad" UI in System Settings stop functioning. You'll have to resort to config file edits later on.
For me on ubuntu 16.04, I finally found that GNOME by conf is overwriting the settings, so I did:
# enable natural scroll in GNOME config,
# it may alter the sign of *ScrollDelta option values defined in /usr/share/X11/xorg.conf.d/*
/usr/bin/gsettings set org.gnome.desktop.peripherals.touchpad natural-scroll true
/usr/bin/gsettings set org.gnome.desktop.peripherals.mouse natural-scroll true
# prevent GNOME from overwriting configured options defined in /usr/share/X11/xorg.conf.d/* at all
/usr/bin/gsettings set org.gnome.settings-daemon.plugins.mouse active false
then things work fine.
fyi I have to use /usr/bin/gsettings coz Anaconda python shipped with a non-functioning gsettings command, while I happens need to prepand anaconda bin to my PATH.
