Powerline is a plug-in to display informational and beautiful statusline for vim, tmux and shell prompt for bash, zsh.
Vim statusline:
How can I install and setup Powerline for different applications and shells in Ubuntu?
Vim statusline:
Install python-pip and git: Open terminal by hitting Ctrl+Alt+T and run:
sudo apt-get install python-pip git
Per user:
In terminal run:
pip install --user git+git://github.com/Lokaltog/powerline
Add ~/.local/bin to $PATH by modifying ~/.profile with your favourite editor:
gksudo gedit ~/.profile
and adding following lines at the end of it:
if [ -d "$HOME/.local/bin" ]; then
PATH="$HOME/.local/bin:$PATH"
fi
System wide:
In terminal run:
su -c 'pip install git+git://github.com/Lokaltog/powerline'
Powerline provides two ways of installing the required fonts. If you're using one of following terminal: Gnome Terminal, Konsole, lxterminal, st, Xfce Terminal, Terminator, Guake, Yakuake then you should use "Fontconfig" method.
Fontconfig: (recommended)
Per User:
Run the following commands in terminal:
wget https://github.com/Lokaltog/powerline/raw/develop/font/PowerlineSymbols.otf https://github.com/Lokaltog/powerline/raw/develop/font/10-powerline-symbols.conf
mkdir -p ~/.fonts/ && mv PowerlineSymbols.otf ~/.fonts/
fc-cache -vf ~/.fonts
mkdir -p ~/.config/fontconfig/conf.d/ && mv 10-powerline-symbols.conf ~/.config/fontconfig/conf.d/
System wide:
sudo mv PowerlineSymbols.otf /usr/share/fonts/
sudo fc-cache -vf
sudo mv 10-powerline-symbols.conf /etc/fonts/conf.d/
Patched font:
Use this method only if "Fontconfig" method doesn't work for you or you're using a terminal other than mentioned above.
~/.fonts/ for per user installation or /usr/share/fonts for system wide installation.fc-cache -vf ~/.fonts to update your font cache, sudo fc-cache -vf to do it system wide.To use patched font in Gvim see this answer and to change the font of your respective terminal check this question: How to change the font of various terminal emulators?. You may have to reboot your system after font installation for changes to take effect.
Vim statusline:
Add following to your ~/.vimrc or /etc/vim/vimrc:
set rtp+=$HOME/.local/lib/python2.7/site-packages/powerline/bindings/vim/
" Always show statusline
set laststatus=2
" Use 256 colours (Use this setting only if your terminal supports 256 colours)
set t_Co=256
Bash prompt:
Add the following line to your ~/.bashrc or /etc/bash.bashrc:
if [ -f ~/.local/lib/python2.7/site-packages/powerline/bindings/bash/powerline.sh ]; then
source ~/.local/lib/python2.7/site-packages/powerline/bindings/bash/powerline.sh
fi
Zsh prompt:
Add the following line to your ~/.zshrc or /etc/zsh/zshrc:
if [[ -r ~/.local/lib/python2.7/site-packages/powerline/bindings/zsh/powerline.zsh ]]; then
source ~/.local/lib/python2.7/site-packages/powerline/bindings/zsh/powerline.zsh
fi
Tmux statusline:
Add the following line to your ~/.tmux.conf:
source ~/.local/lib/python2.7/site-packages/powerline/bindings/tmux/powerline.conf
set-option -g default-terminal "screen-256color"
If your terminal supports 256 colours, set TERM environment variable to xterm-256color by modifying ~/.bashrc or /etc/bash.bashrc and adding following line:
export TERM=xterm-256color
To check if your terminal supports 256 colours check the documentation of your terminal or google it. Most popular terminals support 256 colours.
Vim statusline:
set rtp+=/usr/local/lib/python2.7/dist-packages/powerline/bindings/vim/
set laststatus=2
set t_Co=256
Bash prompt:
if [ -f /usr/local/lib/python2.7/dist-packages/powerline/bindings/bash/powerline.sh ]; then
source /usr/local/lib/python2.7/dist-packages/powerline/bindings/bash/powerline.sh
fi
Zsh prompt:
if [[ -r /usr/local/lib/python2.7/dist-packages/powerline/bindings/zsh/powerline.zsh ]]; then
source /usr/local/lib/python2.7/dist-packages/powerline/bindings/zsh/powerline.zsh
fi
Tmux statusline:
source /usr/local/lib/python2.7/dist-packages/powerline/bindings/tmux/powerline.conf
If your terminal supports 256 colours, Set TERM environment variable to xterm-256color by modifying ~/.bashrc or /etc/bash.bashrc and adding following line:
For detailed information on configuring Powerline: Configuration.
To uninstall Powerline run one of following commands in terminal:
To uninstall per user installation:
pip uninstall powerline
To uninstall system wide installation:
su -c 'pip uninstall powerline'
Source: Powerline beta documentation
If you're installing Powerline just for Vim you should try vim-airline which is more customizable and lightweight.
As of Ubuntu 14.10 (utopic), a powerline package is available in the universe repository. To install it, just run this command in your terminal :
sudo apt-get install powerline
Alternatively, you should be able to install it by using the Ubuntu Software Center.
Though this has been answered, it seems the solution may also be somewhat overkill in terms of the installment for Bash at this point in time. Unaware am I if Powerline was available in the earlier repos, but it is available in the current repos. That being said, it's much less abstracted for Bash right now.
sudo apt install powerline
.bashrc with your text editor of choice.gedit ~/.bashrc
And append this to the document;
if [ -f `which powerline-daemon` ]; then
powerline-daemon -q
POWERLINE_BASH_CONTINUATION=1
POWERLINE_BASH_SELECT=1
. /usr/share/powerline/bindings/bash/powerline.sh
fi
/etc/bash.bashrc as root with your text editor of choice.sudo su followed by gedit /bash.bashrc
and append this to the document;
powerline-daemon -q
fi
With the latest install of powerline things have gotten a lot easier. Here is how I went about it.
Use the following settings in your .vimrc:
Bundle 'Lokaltog/powerline', {'rtp': 'powerline/bindings/vim/'}
" Powerline setup
set laststatus=2
set term=xterm-256color
set termencoding=utf-8
set guifont=Ubuntu\ Mono\ derivative\ Powerline:10
" set guifont=Ubuntu\ Mono
let g:Powerline_symbols = 'fancy'
~/.vim/bundles/powerline/fonts folder and double click the font that is in there. Install it./etc/fonts/conf.d)Note: you do not need to install it via pip anymore.
If you just want the bash extension, I wrote a small script that automates the manual steps that Basharat Sialvi wrote (many thanks for that complete reference).
In synthesis (but please, have a look at the script first as I won't be responsible if it throws your computer out of the window or delete your files):
git clone git@github.com:vincepii/ubuntu-powerline-bash.git
cd ubuntu-powerline-bash
./install.sh
https://thealarmclocksixam.wordpress.com/2016/02/28/quickly-setup-powerline-for-bash-in-ubuntu/
