72
My university uses WPA2 Enterprise encryption for students to login their wireless. In NetworkManager I have keyed in everything that they needed
  • Security : WPA & WPA2 Enterprise
  • Authentication : Protected EAP (PEAP)
  • CA certificate is not needed
  • PEAP version : Automatic
  • Inner authentication : MSCHAPv2
  • Username and Password are correct.
Everytime I try to connect, I get a window asking me to input my password over and over again
Balraj McCoy
  • 1,114
7 Answers7
43
There is a bug report here: https://bugs.launchpad.net/ubuntu/+source/network-manager/+bug/1104476
A workaround is to remove the line
system-ca-cert=true
from the configuration file found in /etc/NetworkManager/system-connections/
chionis
  • 479
30
Here's a work around.
  1. Open a terminal (Alt + F2) and run the following commands:
    cd /etc/NetworkManager/system-connections
    sudo touch SSID #SSID is the name of the profile, e.g. eduroam
    sudo nano SSID
  2. Then edit the "SSID" profile as following:
    [ipv6]
    method=auto
    [connection]
    id=SSID #(e.g.EDUroam)
    uuid=9e123fbc-0123-46e3-97b5-f3214e123456 #unique uuid will be created upon creation of this profile
    type=802-11-wireless
    [802-11-wireless-security]
    key-mgmt=wpa-eap
    auth-alg=open
    [802-11-wireless]
    ssid=SSID
    mode=infrastructure
    mac-address=0A:12:3C:DA:C1:A5
    security=802-11-wireless-security
    [802-1x]
    eap=peap;
    identity=studentid123123
    phase2-auth=mschapv2
    password=mypass123123
    [ipv4]
    method=auto
Modify the above file and it should work.
Aditya
  • 13,616
keith
  • 301
I had the same problem at work I followed the instructions and changed the system-ca-cert=false but I also had to go in and change the wireless driver settings once I made the changes it connected right up. check out the link where I got the info below
http://wireless.kernel.org/en/users/Documentation/wpa_supplicant
-o<driver> and -O<ctrl>
/usr/share/dbus-1/system-services/fi.epitest.hostap.WPASupplicant.service
[D-BUS Service]
Name=fi.epitest.hostap.WPASupplicant
Exec=/sbin/wpa_supplicant -u -f /var/log/wpa_supplicant.log
User=root
[D-BUS Service]
Exec=/sbin/wpa_supplicant -u -onl80211 -O/var/run/wpa_supplicant
User=root
BuZZ-dEE
  • 14,533
More recently, many eduroam deployments have broken on Ubuntu 22.04 LTS because they still use insecure renegotiation, which was deprecated by RFC 5746 in 2010 and for which OpenSSL dropped support for around March 2010 (along with TLS 1.0 and 1.1). Until your university fixes its network, you can re-enable insecure renegotiation by editing some config files.
The following steps were contributed to Launchpad Bug #1958267 by users "nfalse" (#22) and Simon Chopin (#36)
Step 1: Create specific openssl.cnf for wpa_supplicant
$ sudo cp /etc/ssl/openssl.cnf /etc/wpa_supplicant/
This will ensure that enabling TLS 1.0 applies only to WPA negotiations, which will mitigate the security impact of this change somewhat.
Step 2: Enable legacy TLS in the copied config file
As root, edit the new config file:
$ sudo gedit /etc/wpa_supplicant/openssl.cnf
Then, find the following lines:
[openssl_init]
providers = provider_sect
Immediately thereafter, insert the following lines:
ssl_conf = ssl_sect
[ssl_sect] system_default = system_default_sect
[system_default_sect] Options = UnsafeLegacyRenegotiation CipherString = DEFAULT@SECLEVEL=1
Step 3: Make wpa_supplicant use the new configuration
As root, edit /usr/lib/systemd/system/wpa_supplicant.service.
$ sudo gedit /usr/lib/systemd/system/wpa_supplicant.service
Find the following lines:
[Service]
Type=dbus
BusName=fi.w1.wpa_supplicant1
ExecStart=/sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
ExecReload=/bin/kill -HUP $MAINPID
After BusName, insert Environment="OPENSSL_CONF=/etc/wpa_supplicant/openssl.cnf". The whole section should read as follows:
[Service]
Type=dbus
Step 4: Restart the wpa_supplicant
You can either reboot your whole computer at this point or just run the following commands:
$ sudo systemctl daemon-reload
$ sudo systemctl restart wpa_supplicant.service
You might also need to specify the Domain of your enterprise by adding it before the username like so: Domain Name\Username beside commenting/deleting the above mentioned line..
bingorabbit
  • 131
I assume that you're using self-signed certificate (you said: "CA certificate is not needed"). If so, make sure that the certificate is trusted by you when establishing the connection.
Guardian
  • 180
  1. Try resetting your password (by contacting the sys admin or using an online form to send password reset link to your email address)
  2. via network manager gui, edit the wifi connection to update the password field with the new one and save.
  3. Reconnect to your wifi and it should be working now!
SrvfUser
  • 2,085
