I've looked at similar posts on this topic but nothing so far is working.
Unfortunately I can connect to my Colleges Guest WIFI but not the actual WiFi. The school is running security: WPA & WPA2 Enterprise and PEAP authentication.
Some of the things I’ve tried is:
  1. changing the config file inside /etc/NetworkManager/system-connections. My config file does not have
    system-ca-cert=true
  2. Attaching the schools CA Certificate (From the IT Deparment)
  3. Changing the user name schema to Domain\Username
  4. Trying to install drivers (however that’s a rabbit hole inside a rabbit hole) etc.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
