63
I am trying to install Ubuntu 12.10 for quite some time, and passing hurdles one by one. Now I am in a situation as follows.
I have got a PC and 10 GB HDD which will be totally dedicated to Ubuntu so no option of Wubi and dual boot.
I was trying to install from DVD, but it is getting stuck at "Out of frequency" error. So I had to adapt for USB boot option. But my PC is USB non bootable, so workaround is "Plop Boot Manager". So I am doing the installation procedure as follows:
  1. starting from a CD drive which is having plop installed.
  2. opting for for USB boot in plop options.
  3. booting begins from USB.
  4. monitor eventually gives "out of frequency" error
  5. press Shift+Alt+F1 to get the terminal.
  6. open the grub with sudo nano /etc/default/grub.
  7. do necessary changes.
  8. sudo update-grub.
Now here I am getting error as follows:
/usr/sbin/grub-probe:error:failed to get canonical path of /cow.
My system is
P4 3.06 GHz, 1 GB ram , 10 GB HDD without an OS, monitor CRT lg StudioWorks (7 years old). Mobo Mercury P4 266a NDMx (865 equivalent). The whole system is perfectly in working condition under XP, but it is USB non bootable, and all other devices working perfectly.
What should I do next?
ulkaNCST
  • 769
8 Answers8
47
After booting from the Ubuntu live CD (tried 14.04 and 16.04) I was able to work around this problem by running update-grub chroot'ed to the grub partition. (Substitute /dev/sda1 below with whatever partition you installed grub on. All commands as root.)
mkdir /mnt/chrootdir
mount /dev/sda1 /mnt/chrootdir
for dir in proc dev sys etc bin sbin var usr lib lib64 tmp; do
    mkdir /mnt/chrootdir/$dir && mount --bind /$dir /mnt/chrootdir/$dir
done
chroot /mnt/chrootdir
grub-install /dev/sda # May not be required
update-grub2
Nathan Kidd
  • 892
Find your drive that's supposed to boot with
mount
Or
parted -l
Or
fdisk /dev/sda
And type p to list the partitions, look for type 83.
(If you've got Fedora you might have to use the commands vgs and lvs and if you've got mdraid you might have to cat /proc/mdstat or mdadm -A --scan or insmod raid1 or insmod raid5 and then mdadm -A --scan) and you will use /dev/md0 or /dev/mapper/my-vg instead of /dev/sda
then try mount it
mkdir /mnt
cd /mnt
ls -l
Is this your drive? Cool!
grub-install --recheck --root-directory=/mnt /dev/sda
(Or whichever /dev drive your root is, with it's mounted path)
grub-install --recheck --root-directory=/mnt /dev/sda --force
(Force it if it doesn't like your partitions.)
Now it should boot into grub, and you can use the grub commands to boot up, after rebooting and selecting the right boot drive from the BIOS Setup, or by pressing ESC, F8 or F12 depending on your BIOS and whether you are quick enough, then at the Grub prompt - you can use tab completion to find it if it's not (hd0,1) but (hd1,3) or something else instead, but beware, tab completion sometimes hangs for a few seconds if grub can't read the filesystem. Once booted into Grub you can try to boot with:
insmod linux
ls
root=(hd0,1)
linux /boot/vmlinuz root=/dev/sda1
initrd /boot/initrd
boot
Or, hopefully you've still got an intact grub.cfg file...
ls
ls (hd0,1)/
ls (hd0,1)/boot
configfile (hd0,1)/boot/grub.cfg
Grub 1 allows you to do the installation from Grub:
install (hd0,1)
Once booted from the correct drive, you can retry update-grub and grub-install. If it still fails, you can try:
grub-mkconfig -o /mnt/boot/grub/grub.cfg
Your paths may differ of course, so just play with these commands until you can see what's where and what's going on.
It might be a sign of imminent hard drive failure at worst, or at best maybe just a partition flag or boot file that got overwritten accidentally, or a deliberately- or accidentally broken installer from another OS.
Dagelf
  • 1,476
12
Revised solution based on code above
The solution from above will not work totally without problems because it mounts the boot partition into the / (root) of the file system. That makes grub complain that /boot does not exist, of course. This will fix that problem:
mkdir /mnt/chrootdir/boot
mount /dev/sda1 /mnt/chrootdir/boot
for dir in proc dev sys etc bin sbin var usr lib lib64 tmp; do mkdir /mnt/chrootdir/$dir && mount --bind /$dir /mnt/chrootdir/$dir ; done
update-grub2  # inside chroot
As you see i also removed the line breaks so that it is easier to execute for everyone.
Another (simpler) solution
If you keep having problems getting it to work you should look to copy the /boot partition onto the / (root) partition. For that start your system with the Ubuntu live boot dvd and open the terminal. Inside it type:
sudo su
fdisk -l
To find out which partitions you have. In my case sda1 is my /boot partition which is about 250MB large and an sda5 which is about 500GB. I use these values in the commands below:
mkdir /mnt/boot/
mount /dev/sda1 /mnt/boot/
mkdir /mnt/root/
mount /dev/sda5 /mnt/root/
cp -R /mnt/boot/ /mnt/root/boot/
Set the bootable flag for the data partition and remove it for the boot partition:
fdisk /dev/sda
b -> 1 (unset the bootable flag for the first partition)
b -> 5 (set the bootable flag for the fifth partition)
w -> write changes to the MBR
Your computer will now look inside the sda5 for the boot files. Time to do the chrooting again, this time with some required folders needed for grub and which are generated by your Ubuntu live disc already:
mkdir /mnt/chrootdir/dev/
mkdir /mnt/chrootdir/proc/
mkdir /mnt/chrootdir/sys/
mount /dev/sda5 /mnt/chrootdir/
mount --bind /dev/ /mnt/chrootdir/dev/
mount --bind /proc/ /mnt/chrootdir/proc/
mount --bind /sys/ /mnt/chrootdir/sys/
chroot /mnt/chrootdir/
Installation finished. No error reported.
If you do not see a message that the grub.cnf file is generated then also run the update command:
update-grub2 /dev/sda
Now you can safely reboot and see the well known boot menu appear again.
This solution was the only one which was working for me after migrating from a physical server to a virtual machine. I hope someone finds this useful!
Tim B.
  • 219
Got the same error. The only problem was that /cow was still mounted on /.
A little sudo umount /cow did the trick.
SinLey
I tried all the solutions and couldn't get it fixed. What worked for me - was to install windows 10(it will create EFI partition), then delete every windows partition except EFI and install Linux. This time Linux will successfully and automatically configure grub
I just made a directory called /cow
mint@mint:~$ sudo mkdir /cow
mint@mint:~$ sudo update-grub
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/50_linuxmint.cfg'
Generating grub configuration file ...
grub-probe: error: unknown filesystem.
Found linux image: /boot/vmlinuz-6.8.0-51-generic
Found initrd image: /boot/initrd.img-6.8.0-51-generic
/usr/sbin/grub-probe: error: unknown filesystem.
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
Found Linux Mint 22.1 Xia (22.1) on /dev/nvme0n1p4
Adding boot menu entry for UEFI Firmware Settings ...
done
user68186
  • 37,461
I know, it's a old problem, but I had the same troubles today with the actual version of mint-linux (ubuntu-based). I found a very simply solution! :-) Take off the internet-connection during the first installation. This stop loading of a non compatible grub2. Make the update of all after installation has finished.
anonymous2
  • 4,325
-6
It is the update-grub command which will give you the error when using it from a live cd. I faced with a similar situation when I was doing a GRUB rescue. Also grub-install wasn't in my path for some reason, so I had to run it with /usr/sbin/grub-install.
grub-install accepts a --boot-directory option, to set up GRUB to boot to a system different from the one that is currently running. Here is the relevant manual page.
