I am trying to install xubuntu 20.04 on a small Thinkpad x121e netbook with 8GB Men and a 250GB SSD. Until now I had Ubuntu 16.04 on it which installed without any problems. The installation runs until it tries to install grub but end with the following error:
Unable to install grub on/dev/sda
Executing 'grub-install /dev/sda' failed
This is a fatal error
No dual boot or any complex or exotic settings. I erased the drive and removed all previous partition with gparted. I did a standard/default setting and also tried to tune the partitioning, using tips from some other posts about similar problems but without success until now.
Lots of error I found in other posts are often when users try to install in dual boot, which is not my case. I really just want a standard installation...
Any hints? Or is the xubuntu installer buggy???
Cheers
